olitaylor07
Badger Badger
Jul 15, 2012
1,955
West Yorkshire
Bought my VAG-COM off fleebay which I will post a link to £57.99 off a guy in huddersfield.
And managed a needle sweep :)
Also disabled cornering fog lights when indicating, reversing etc and put digital MPH on aswell only took 5 mins :)
However after changing my needle sweep I did a fault test and came up with this fault
09-Cent Elec - Status Malfunction 0010
Fault found 1
00185 - Control Circuit. Relay for supply voltage Terminal 15
012- Electrical Fault in Circuit - Intermitent.
I never had this fault before and looks like it happened after I changed my needle sweep. Can you VAG-COM pros help me out.
Have you cleared the faults and see if they come back? They might be old faults from previous owner if there was one
Somebody else mentioned that. I should have also tried the fault test before I changed everything. Its just wierd how I changed everything around that module then the fault code comes up. Will try and clear it tomorrow.
Chances are they cleared the faults, but didnt fix the problem?, thus when you made your changes, it refreshed the system and re-found them.
Not entirely sure about how the ECU software works tho.
