Hi guys I've got a problem with irregular idle speed on my 2010 Cupra. it seems fine when cold but once the car warms up the idle starts to bounce between 1k and 2.5k. I also get a slight over run when turning off the ignition. other than that the car runs and drives fine when in gear no power loss etc I've done a vcds autoscan and its brought up 2 error codes -
004243 - Bank 1; Fuel Measuring System 2 P1093 - 008 - Malfunction - Intermittent
001287 - Idle Control System RPM P0507 - 001 - Higher than Expected
I've had a look around for vacuum leaks (only visually) and i can't see anything out of the ordinary
it's been suggested to me that my PCV valve may be on the way out but i just wanted to check opinions before i shell out for a new one. Any thoughts? Cheers
