Noam
182
All is good fuse wise but the original 9 year pump is cutting out and not always working.
How important is this pump during driving? . I know it's purpose after stalling the engine .
But my mechanic reckons it's important while driving too.
What to do?
Repair?
Replace?
Any truth in it's importance while driving?
Think mine may be on the way out aswell, started making a strange noise thats not the same as normal. Still works, but it makes a strange whining noise like a strangled cat or something!:confused:
Is it a big job to replace?
Good good, thats another part to add to the list along with an ABS wheel sensor.
Will the turbo get damaged if the 2nd water pump is not working? Suppose, i do anyway though, drive off boost 5mins before the end of the journey to keep the turbo from getting too hot before i turn it off.
After replacing it my mechanic proved using a stethoscope that it works during driving too .
A common misconception disproved then :)
this is also controlled by the trouble some fuse ,the far right on top of the battery i found this out when i bypassed that fuse
Mine does this every now and then, while looking into it I found the noise goes away if you put pressure on the power connector! Almost has if it has a dodgey connection!
Did a quick search in the part numbers thread and i can't seem to find the part number for the secondary water pump. Does anyone have it at all?
