Few questions Regarding Injectors and Mbc ect
DaNnY_LaD
Big Turbo Leon Cupra R
Jun 2, 2007
4,814
Manchester,Walkden
www.myspace.com
Right Ive got all my bits fitted on the cupra nealy
But left to do is
A: Fitting Injectors is this easy and does anyone have a guide or pics of how todo it...
B: I have a idea how to fit my turbosmart mbc but when it comes to tuning it do i slightly adjust it so on my boost gauge on WOT it Peaks at 1.45bar then holds at what ever? As this what Boost Most gt2x lads run..
Then log everything If so what logs should i do..
Reuvers
I is a Dutch man!
Oct 30, 2007
3,374
Netherlands
changing the injectors is easy.
You'll have to remove fuel rail and bolts on top of manni. then you can pull the injectors out one by one (or all together as they are attached to the rail).
Then there are small metal clips on the top of the injectors that you easily undo and the injector releases
as for boost I do not know the answer sorry
