First go at Datalogging with VAG-COM
speedsix
Leon Cupra R 225
Oct 30, 2004
825
Took the ibiza out tonight and did a few runs with VAG-COM.
Car is Revo'd with a RamAir filter and magnex rear box.
Peak MAF readout was 162.22g/s @ 5000rpm. Seems to be reading every 2secs, is this correct? Maybe the maf readout was higher after 5000rpm but it had dropped off by the next reading obviously.
Intake temps reached 46c.
CF values were as follows. Any thoughts if I could increase boost/timing with an SP3 looking at these values?
Code:
TIME
STAMP	 CF	 CF	 CF	 CF
1.17	0	0	0	0
2.69	0	0	0	0
4.47	0	0	0	0
5.98	0	0	0	0
7.78	0	0	0	0
9.6	0	0	0	0
11.37	3.8	0	0	1.5
13.17	0	0	0	0
14.97	0	0	0	0
16.84	3.8	3	3	0
18.56	0	0	0	0
20.06	0	0	0	0
21.76	0.8	0	0	0
23.41	0.8	0	0	0
25.16	0	0	0	0
26.76	0	0	0	0
28.56	0	0	0	0
30.42	0	0	0	0
32.16	0	0	0	0
33.66	0	0	0	0
35.26	0	0	0	0
37.09	0	0	0	0
38.86	0	0	0	0
40.46	3.8	1.5	0	1.5
42.15	0	0	0	0
43.87	0	0	0	0
45.65	0	3	0	0
47.25	0	3	0	0
48.75	0	0	0	0
50.36	0	0.8	0	0
52.15	0	0	0	0
53.86	0	0	0	0
55.65	0	0	0	0
57.38	0	0	0	0
59.15	0	0	0	0
60.84	0	0	0	0
62.44	0	0	0	0
64.24	0	0	0	0
65.94	0	0	0	0
67.64	0	0	0	0
69.14	0	0	0	0
70.85	3	4.5	3	0
72.65	3	4.5	3	0
74.44	0	0	0	0
75.94	0	0	0	0
77.75	0	0	0	0
79.54	0	0	0	0
81.24	0	0	0	0
82.84	0	0	0	0
84.64	0	0	0	0
86.43	0	0	0	0
88.13	0	0	0	0
89.73	0	0	0	0
91.53	3.8	5.3	0.8	0.8
93.33	0	0	0	0
95.13	0	0	0	0
96.73	0	0	0	0
98.55	0	3	0.8	3.8
100.33	3	2.3	3.8	3
102.14	0	0	0	0
103.83	0	0	0	0
105.54	0	0	0	0
107.22	1.5	4.5	2.3	1.5
108.92	0	3.8	0	0.8
110.62	0	0	0	0
112.43	0	0	0	0
114.23	0.8	4.5	1.5	0
116.02	0	3	0	0
117.62	0	0	0	0
119.34	0	0	0	0
121.12	0	0	0	0
122.86	0	0	0	0
124.62	0	0	0	0
126.47	0	0	0	0
128.22	0	0	0	0
129.92	0	0	0	0
131.52	0	0	0	0
133.37	0	0	0	0
135.12	0	0	0	0
136.72	0.8	3	1.5	0
138.31	0	3	0.8	0
139.93	0	0	0	0
141.72	0	0	0	0
143.52	0	0	0	0
145.31	0	0	0	0
147.05	0	0	0	0
148.7	0	0	0	0
150.3	0	0	0	0
151.8	0	0	0	0
153.5	0	0	0	0
155.2	0	0	0	0
157.01	0	0	0	0
158.8	0	0	0	0
160.41	0	0	0	0
162.24	0	0	0	0
164.02	1.5	3.8	2.3	0
165.71	0	0	0	0
167.55	0	0	0	0
169.32	0	0	0	0
171.14	3	3	0	3
172.9	3	3	0	3
174.77	0	0	0	0
176.49	0	0	0	0
178.2	0	0	0	0
180	0	0	0	0
181.85	0	0	0	0
183.5	0.8	0.8	0	0.8
185.31	0.8	0.8	0	0.8
187.09	0	0	0	0
188.91	0	0	0	0
190.69	0	0	0	0
192.4	0	0	0	0
194.19	0	0	0	0
196	0	0	0	0
197.79	0	0	0	0
199.48	0	0	0	0
201.19	0	0	0	0
202.98	0	0	0	0
204.81	0	0	0	0
206.48	0	0	0	0
208.28	0	0	0	0
210.1	0	0	0	0
211.88	0	0	0	0
213.47	0	0	0	0
215.17	1.5	4.5	1.5	0
216.87	0	2.3	0	0
218.68	0	0	0	0
220.47	0	0	0	0
222.29	0	0	0	0
223.98	0	0	0	0
225.77	0	0	0	0
227.47	0	2.3	0	0
229.31	0	0	0	0
231.1	0	0	0	0
232.88	0	0	0	0
234.67	0	0	0	0
236.54	0	0	0	0
238.26	0	2.3	2.3	0
240.07	0	0	0.8	0
241.76	0	0	0.8	0
243.51	0	0	0.8	0
245.26	0	0	0	0
247.07	0	0	0	0
248.77	0	0	0	0
250.56	0	0	0	0
252.26	0	0	0	0
254.06	0	0	0	0
255.67	1.5	1.5	0	1.5
257.46	0	0	0	0
259.15	0	0	0	0
260.85	0.8	0.8	0	0.8
262.46	0	0	0	0
264.27	0	0	0	0
265.86	0	0	0	0
267.56	0	0	0	0
269.35	0	0	0	0
271.08	0.8	0.8	0	0.8
272.85	0	0	0	0
274.65	0	0	0	0
276.27	0	0	0	0
277.97	0	0	0	0
279.76	0	0	0	0
281.46	0	0	0	0
283.15	0	0	0	0
284.95	0	0	0	0
286.74	0	0	0	0
288.56	0	0	0	0
290.34	0	0	0	0
292.05	0	0	0	0
293.85	0	0	0	0
295.46	0	0	0	0
297.26	0	0	0	0
299.05	0	0	0	0
300.75	0	0	0	0
302.45	0	0	0	0
304.25	0	0	0	0
306.03	0	0	0	0
307.83	0	0	0	0
309.43	1.5	1.5	1.5	1.5
311.13	0	0	0	0
312.93	0	0	0	0
314.63	1.5	4.5	2.3	0
316.13	0	0	0	0
317.73	1.5	4.5	2.3	0
319.54	1.5	2.3	0	1.5
321.26	0	0	0	0
323.04	0	0	0	0
324.74	0	0	0	3
326.53	0	3	0	3
328.33	0	0	0	0
330.13	0	0	0	0
331.83	0	0	0	0
333.62	0	0	0	0
335.32	0	0	0	0
337.02	1.5	1.5	0	1.5
338.85	1.5	1.5	0	1.5
340.62	0	0	0	0
342.33	0	0	0	0
343.93	0	0	0	0
345.75	0	0	0	0
347.41	0	0	0	0
349.22	0	0	0	0
351.02	0	0	0	0
352.88	0	0	0	0
354.61	1.5	4.5	0.8	0
356.44	0	3	0	0
358.23	0	3	0	0
360.07	0	0	0	0
361.81	0	0	0	0
363.62	0	0	0	0
365.31	1.5	2.3	1.5	0
367.13	0	0	0	0
368.91	0	0	0	0
370.6	0	0	0	0
372.2	0	0	0	0
373.94	0	0	0	0
375.7	0	0	0	0
377.42	0	0	0	0
379.11	0	0	0	0
380.92	0	0	0	0
382.7	0	0	0	0
384.32	0	0	0	0
386.1	0	0	0	0
387.89	0	0	0	0
389.7	0	0	0	0
391.49	0	0	0	0
393.19	0	0	0	0
394.9	0	2.3	0	0
396.7	0.8	1.5	0	0
398.4	0	3	0	0
400.12	0	3	0	0
401.89	0	0	0	0
403.7	0	0	0	0
405.29	0	0	0	0
407.09	0	3	0	0
408.8	0	0	0	0
410.59	0	0	0	0
412.38	1.5	4.5	2.3	0
414.08	0.8	3.8	2.3	0
415.8	1.5	4.5	2.3	0
417.59	1.5	4.5	2.3	0
419.29	1.5	0	0	0
420.98	0.8	3.8	2.3	0
422.71	0	2.3	0.8	0
424.48	0	0.8	0	0
426.18	0	0.8	0	0
427.99	0	0.8	0	0
429.69	0	0	0	0
431.49	1.5	3	0	0
433.28	0	0	0	0
435	0	0	0	0
436.78	0	0	0	0
438.58	0	0	0	0
440.37	0	0	0	0
442.23	0	0	0	0
443.97	0.8	3	0	0
445.77	0.8	0.8	0.8	0.8
447.57	0	0	0	0
449.31	0	0	0	0
451.07	0.8	3	0	0
452.67	0	0	0	0
454.36	0	0	0	0
456.12	0	0	0	0
457.86	0	0.8	0	0
459.66	0	0	0	0
461.36	0.8	2.3	0	0
463.09	0.8	1.5	0	0
464.86	0.8	1.5	0	0
466.46	1.5	3	0	0
468.16	1.5	1.5	1.5	1.5
470.01	0	0	0	0
471.76	2.3	3	0	4.5
473.36	0	3	0	3
475.15	1.5	4.5	2.3	0
476.96	0	0	0	0
478.76	1.5	4.5	2.3	3
480.35	1.5	4.5	2.3	0
482.05	1.5	1.5	1.5	1.5
483.7	0	0	0	0
485.46	0	0	0	0
487.15	0	0	0	0
488.85	0	0	0	0
490.6	0	0	0	0
492.35	0	0	0	0
493.95	0	0	0	0
495.64	0	0	0	0
497.48	0	0	0	0
499.24	0	0	0	0
500.84	0	0	0	0
502.65	0	0	0	0
504.45	0	0	0	0
506.24	0	0	0	0
cordobabrendy
FOOORRREEE!
Aug 24, 2001
7,642
belfast
if your logs are only reading every second and a half then your pc might be a little slow, i had a p4m laptop and i was getting 1.x samples per second (when using all three channels, 3 samples per sec if not all channels were logged)
if you advance timing more those 4.5's etc will get higher and cause a little retarting, the figures dont show rpm though so thats not conclusive.
speedsix
Leon Cupra R 225
Oct 30, 2004
825
Would it have anything to do with the baud settings for the cable? usb set to com2.
cordobabrendy
FOOORRREEE!
Aug 24, 2001
7,642
belfast
i never changed any settings so unless you have, i dunno, try logging one block then two and finally three for a few secs, see how they go.
speedsix
Leon Cupra R 225
Oct 30, 2004
825
Just been out again this morning, I've speeded up the samples as per the website so here's some more accurate figures..
MAF peak was 162.72g/s @ 5080rpm, it's a standard K03 btw.
Code:
287.36	0	0	0	0	286.88	1880	11.3	1.23	4.19
288.52	0	0	0	0	287.89	2360	10.5	1.64	5.72
289.56	0	0	0	0	289.07	3200	33.1	3.69	22.14
290.57	0	0	0	0	290.07	3240	19.5	2.05	11.92
291.56	0	0	0	0	291.08	3200	25.6	3.28	17.33
292.56	0	0	0	0	292.07	3320	43.6	4.92	29.25
293.57	0	0	0	0	293.08	3600	78.9	8.61	56.92
294.57	0	0	0	0	294.06	4240	162.4	20.91	144.89
295.68	0	0	0	0	295.15	5080	168.4	23.37	162.72
296.67	0	0	0	0	296.18	3360	12	1.23	4.56
297.66	0	0	0	0	297.17	3360	54.1	6.56	39.5
298.68	0	0	0	0	298.17	3600	75.9	7.79	48.42
299.68	0	0	0	0	299.17	3720	51.9	5.74	36.19
300.67	0	0	0	0	300.18	3800	42.9	4.51	27.19
301.67	0	3	0	0	301.17	3800	33.8	4.51	26.92
302.77	0	2.3	0	0	302.24	3960	92.5	10.66	68.33
303.77	0	0.8	0	0	303.27	4240	103	12.3	83.39
304.77	0	0	0	0	304.27	4320	34.6	4.1	27.5
305.79	0	0	0	0	305.28	4320	29.3	3.28	24.67
306.76	0	1.5	0	0	306.26	4400	72.9	8.2	62.06
307.76	0	0	0	0	307.26	4760	176.7	24.19	161.5
308.79	0	0	0	0	308.27	4040	19.5	4.1	29
309.86	0	0	0	0	309.34	3840	63.2	6.97	48.47
310.86	0	0	0	0	310.36	3880	55.6	6.15	40.36
311.86	0	0	0	0	311.36	3880	45.9	4.92	33.11
312.87	0	0	0	0	312.36	3880	34.6	4.1	25
313.86	0	0	0	0	313.36	3880	35.3	4.1	25.64
314.89	0	0	0	0	314.36	3880	36.1	4.1	25.81
315.92	0	0	0	0	315.37	3840	20.3	2.46	14.58
317.05	0	0	0	0	316.52	3800	34.6	4.1	26.72
318.07	0	0	0	0	317.56	3800	35.3	4.1	25.72
319.06	0	0	0	0	318.56	3760	26.3	3.28	18.19
320.06	0	0	0	0	319.56	3720	33.8	4.1	26.03
321.06	0	0	0	0	320.55	3720	30.1	3.28	19.75
322.07	0	0	0	0	321.57	3760	114.3	15.17	97.75
323.23	0	0	0	0	322.57	4000	191.7	25.01	148.89
324.26	0	0	0	0	323.75	4320	182	24.19	148.75
325.27	0	0	0	0	324.78	4560	178.2	24.19	154.17
326.26	0	0	0	0	325.77	4760	169.9	22.96	154.94
327.25	0	0	0	0	326.75	4880	51.1	11.07	60.44
328.26	0	0	0	0	327.78	4640	15	0	14.39
329.24	0	0	0	0	328.76	4360	8.3	0	7.58
330.41	0	0	0	0	329.79	4240	12.8	0	7.94
331.44	0	0	0	0	330.96	4080	12.8	0	16.19
332.45	0	0	0	0	331.94	4000	9.8	0	5.72
333.45	0	0	0	0	332.95	3920	18.8	2.05	15.03
334.46	0	0	0	0	333.94	3880	50.4	5.74	40.75
335.45	0	0	0	0	334.95	3880	45.9	4.92	34.92
336.45	0	0	0	0	335.96	3920	45.1	5.33	32.94
337.55	0	0	0	0	337.06	3920	38.3	4.1	26.44
338.55	0	0	0	0	338.05	3880	33.8	4.1	25
339.55	0	0	0	0	339.06	3880	36.1	4.1	26.19
340.55	0	0	0	0	340.06	3880	42.1	4.51	30.44
341.55	0	0	0	0	341.08	3840	42.1	4.51	30.61
342.55	0	0	0	0	342.04	3960	151.9	19.68	133.25
343.56	0	0	0	0	343.06	4200	186.5	24.6	147.47
344.65	0	0	0	0	344.12	4440	179.7	24.19	152.25
345.66	0	0	0	0	345.15	4720	173.7	23.37	154.81
346.65	0	0	0	0	346.16	4880	166.9	22.96	154.81
347.67	0	0	0	0	347.15	5040	162.4	22.55	157.11
348.76	0	0	0	0	348.24	5120	45.1	2.05	0
349.73	0	0	0	0	349.25	4800	9.8	0	0.69
350.78	0	0	0	0	350.23	4560	13.5	0	19.83
351.93	0	0	0	0	351.37	4280	12	0	4.33
352.93	0	0	0	0	352.45	4120	10.5	0	1.14
353.95	0	0	0	0	353.43	4000	13.5	0	14.25
354.93	0	3	0	0	354.44	3440	13.5	0	17.14
355.93	0	3	0	0	355.43	2080	12.8	0	0
356.93	0	0	0	0	356.43	3080	22.6	2.87	14.08
358	0	0	0	0	357.43	3040	46.6	5.33	28.61
359.04	0	2.3	0	0	358.55	3040	51.9	6.15	31.28
360.04	0	0	0	0	359.54	3080	78.2	11.07	54.11
361.05	0	0	0	0	360.55	3160	94.7	10.66	55.44
362.04	0	0	0	0	361.54	3160	63.2	6.97	37.31
363.04	0	0	0	0	362.56	3160	51.1	5.74	30.08
364.05	0	0	0	0	363.54	3200	46.6	4.92	26.78
365.18	0	0	0	0	364.57	3160	42.1	4.92	25.25
366.23	0	0	0	0	365.74	3200	120.3	14.35	85.44
367.24	0	0	0	0	366.73	3360	189.5	23.37	122.94
368.23	0	0	0	0	367.74	3520	185	22.96	126.08
369.22	0	0	0	0	368.73	3680	182	22.96	130.78
370.24	0	0	0	0	369.73	3800	178.9	22.96	130.28
371.25	0	0	0	0	370.72	3920	124.1	15.17	69.83
372.35	0	0	0	0	371.8	3880	16.5	1.23	0
373.32	0	0	0	0	372.82	3720	12	0	0.06
374.33	0	0	0	0	373.82	3600	12.8	0	4.53
375.32	0	0	0	0	374.85	3480	12	0	3.33
376.32	0	0	0	0	375.83	3320	11.3	0	0.78
377.32	0	0	0	0	376.82	3240	10.5	0	0.42
378.32	0	0	0	0	377.82	3160	9.8	0	1.69
379.42	0	0	0	0	378.89	3080	9	0	5.5
380.42	0	0	0	0	379.92	3000	8.3	0	4.61
381.42	0	0	0	0	380.93	2960	18.8	2.46	12.06
382.43	0	0.8	0	0	381.93	2920	40.6	4.51	23.53
383.42	0	0	0	0	382.93	2920	46.6	4.92	25.97
384.42	0	0	0	0	383.94	2920	43.6	4.92	24.19
385.46	0	0	0	0	384.93	2920	50.4	5.74	28.58
386.63	0	0	0	0	386.14	2960	51.1	5.74	28.75
387.63	0	0	0	0	387.13	2960	48.1	5.33	26.03
388.63	0	0	0	0	388.13	2960	40.6	4.51	22.28
389.63	0	0	0	0	389.13	2960	40.6	4.51	22.25
390.62	0	0	0	0	390.12	2960	40.6	4.51	21.83
391.63	0	0	0	0	391.12	2920	45.1	4.92	25.25
392.69	0	0	0	0	392.11	2920	45.9	5.33	25.11
393.82	0	0	0	0	393.25	2960	37.6	4.1	20.31
394.82	0	0	0	0	394.32	2920	51.9	6.56	31.28
395.82	0	0	0	0	395.31	2960	61.7	6.56	34.31
396.82	0	0	0	0	396.31	3000	63.2	6.97	35.78
397.82	0	0	0	0	397.32	3000	51.9	5.74	28.89
398.81	0	0	0	0	398.32	3000	45.9	5.33	25.89
399.99	0	0	0	0	399.35	3000	45.1	4.92	25.11
401.01	0	0	0	0	400.51	3000	45.1	4.92	25.42
402.02	0	0	0	0	401.51	3040	72.2	8.2	44.19
403.01	0	0	0	0	402.52	3080	77.4	8.61	45.61
404.03	0	0	0	0	403.52	3120	78.2	8.61	47.03
405.02	0	0	0	0	404.54	3160	58.6	6.56	35.22
406.01	0	0	0	0	405.53	3160	54.1	6.15	32.89
407.16	0	0	0	0	406.63	3200	50.4	5.74	29.69
408.22	0	0	0	0	407.71	3160	38.3	4.1	21.11
409.22	0	0	0	0	408.73	3120	26.3	2.87	14.47
410.22	0	0	0	0	409.71	3080	20.3	2.46	11.17
411.21	0	0	0	0	410.72	3080	16.5	2.05	9.39
412.22	0	0	0	0	411.7	3040	27.1	3.28	16.11
413.22	0	0	0	0	412.71	3000	56.4	6.56	35.44
414.32	0	0	0	0	413.78	3040	41.4	4.51	22.19
415.32	0	0	0	0	414.8	3000	40.6	4.51	23.36
416.31	0	0	0	0	415.81	3040	57.1	6.56	33.86
417.3	0	0	0	0	416.81	3040	63.2	6.97	36.83
418.31	0	0	0	0	417.82	3080	64.7	8.2	41.61
419.33	0	0	0	0	418.82	3120	72.9	8.2	42.44
420.34	0	0	0	0	419.81	3160	59.4	6.15	33.17
421.51	0	0	0	0	420.97	3160	49.6	5.74	29.03
422.51	0	0	0	0	422	3160	36.1	4.1	20.67
423.52	0	0	0	0	423.01	3120	26.3	2.87	14.67
424.5	0	0	0	0	424.02	3080	29.3	3.28	17.86
425.52	0	0	0	0	425.01	3080	33.8	4.1	20.83
426.5	0	0	0	0	426.01	3080	45.9	5.33	27.67
427.57	0	0	0	0	427.02	3080	44.4	4.92	25.36
428.61	0	0	0	0	428.13	3040	38.3	4.51	22.06
429.61	0	0	0	0	429.11	3040	39.1	4.51	22.14
430.61	0	0	0	0	430.1	3040	44.4	4.92	25.92
431.61	0	0	0	0	431.11	3040	62.4	6.97	36.97
432.6	0	0	0	0	432.12	3080	69.9	7.79	41.5
433.62	0	0	0	0	433.11	3120	63.2	6.56	34.33
434.67	0	0	0	0	434.1	3160	45.9	4.92	25.33
435.69	0	0	0	0	435.21	3120	41.4	4.51	23.31
436.7	0	0	0	0	436.2	3120	31.6	3.28	16.33
437.7	0	0	0	0	437.2	3080	18.8	2.87	14.5
438.69	0	0	0	0	438.19	3040	26.3	2.87	14.97
439.7	0	0	0	0	439.2	3040	24.1	2.87	14.25
440.7	0	0	0	0	440.2	3000	23.3	2.46	13.03
441.77	0	0	0	0	441.23	2960	29.3	3.28	16.67
442.8	0	0	0	0	442.29	2920	30.1	3.69	17.83
443.8	0	0	0	0	443.3	2920	46.6	4.92	26.53
444.8	0	0	0	0	444.3	2920	36.8	3.69	18.39
445.79	0	0	0	0	445.31	2880	29.3	3.28	14.64
446.79	0	0	0	0	446.29	2880	43.6	4.92	25.53
447.8	0	0	0	0	447.29	2960	117.3	13.94	75.17
448.95	0	0	0	0	448.35	3080	188.7	22.55	111.78
449.99	0	0	0	0	449.5	3320	183.5	22.14	116.75
451.01	0	0	0	0	450.5	3480	182.7	22.55	121.19
452.01	0	0	0	0	451.5	3600	101.5	21.73	100.11
453	0	0	0	0	452.5	3520	13.5	0	0.36
453.99	0	0	0	0	453.5	3440	14.3	2.46	9.28
454.99	0	0	0	0	454.49	3360	15.8	1.64	10.31
456.19	0	0	0	0	455.64	3320	23.3	2.87	16
457.19	0	0	0	0	456.7	3280	36.8	4.1	23.14
458.2	0	0	0	0	457.71	3280	33.8	3.69	21.94
459.19	0	0	0	0	458.69	3240	36.8	4.51	23.72
460.2	0	0	0	0	459.69	3280	103.8	13.94	77.42
461.18	0	0	0	0	460.7	3400	191.7	24.19	129.86
462.25	0	0	0	0	461.68	3560	185.7	22.96	127.31
463.39	0	0	0	0	462.86	3760	180.5	22.14	129.53
464.4	0	0	0	0	463.9	3680	20.3	1.23	5.39
465.38	0	0	0	0	464.88	3600	10.5	0	6.75
466.38	0	0	0	0	465.88	3520	11.3	0	12.81
467.39	0	0	0	0	466.88	3440	10.5	1.64	8.11
468.4	0	0	0	0	467.89	3360	13.5	1.64	8.22
469.47	0	0	0	0	468.89	3320	13.5	1.64	8.67
470.49	0	0	0	0	469.99	3240	32.3	3.69	21.06
471.48	0	0	0	0	470.99	3280	94.7	13.53	70.72
472.48	0	0	0	0	471.98	3400	191.7	23.78	129
473.48	0	0	0	0	472.98	3600	185.7	22.96	126.69
474.49	0	0	0	0	473.98	3760	183.5	23.37	131.53
475.49	0	0	0	0	474.98	3720	16.5	1.64	5.53
476.64	0	0	0	0	476.02	3640	12.8	0	2.36
477.68	0	0	0	0	477.19	3520	11.3	1.23	0
478.68	0	0	0	0	478.18	3520	103.8	13.53	83.08
479.67	0	0	0	0	479.17	3640	191.7	24.19	134.81
480.68	0	0	0	0	480.19	3760	59.4	3.28	0
481.7	0	0	0	0	481.18	3680	14.3	0	0
482.67	0	0	0	0	482.17	3600	14.3	0	16.53
483.8	0	0	0	0	483.25	3520	12.8	0	16.31
484.87	0	0	0	0	484.37	3400	12	0	4.28
485.87	0	0	0	0	485.38	3320	11.3	0	1.22
486.88	0	0	0	0	486.38	3240	10.5	0	1.5
487.87	0	0	0	0	487.37	3160	9.8	0	5.83
488.87	0	0	0	0	488.37	3120	8.3	0	5.17
489.88	0	0	0	0	489.37	3040	8.3	0	5.44
490.97	0	0	0	0	490.44	2960	8.3	0	5.14
491.97	0	0	0	0	491.47	2880	8.3	0	4.42
492.97	0	0	0	0	492.47	2840	9	1.23	5.56
493.99	0	0	0	0	493.48	2800	17.3	2.05	10.03
494.97	0	0	0	0	494.5	2760	22.6	2.46	12.42
495.97	0	0	0	0	495.47	2720	36.1	4.51	19.97
497	0	0	0	0	496.47	2720	38.3	4.51	20.47
498.06	0	0	0	0	497.54	2720	42.1	4.92	22.11
499.06	0	0	0	0	498.56	2720	42.1	4.92	22.19
500.07	0	0	0	0	499.56	2760	42.1	4.92	22.28
501.06	0	0	0	0	500.57	2760	53.4	9.43	37.92
502.06	0	0	0	0	501.56	2880	152.6	18.45	91.47
503.06	0	0	0	0	502.56	3040	177.4	21.32	105.56
504.12	0	0	0	0	503.57	3160	99.2	9.84	37.17
505.17	0	0	0	0	504.69	3120	24.1	3.28	19.03
506.17	0	0	0	0	505.66	3080	12.8	0	13.61
507.16	0	0	0	0	506.66	3000	12.8	0	12.56
508.16	0	0	0	0	507.67	2920	9.8	0	5.56
509.16	0	0	0	0	508.66	2880	9	0	5.11
510.16	0	0	0	0	509.66	2800	8.3	0	4.67
511.22	0	0	0	0	510.67	2760	8.3	0	4.47
512.26	0	0	0	0	511.76	2680	8.3	0	4.25
513.27	0	0	0	0	512.77	2600	23.3	2.87	12.61
514.27	0	0	0	0	513.76	2640	39.1	4.51	20.92
515.27	0	0	0	0	514.78	2640	44.4	5.33	23.83
516.26	0	0	0	0	515.76	2640	51.1	6.56	28.33
517.27	0	3	0.8	0	516.79	2680	85.7	9.84	47.36
518.37	0	1.5	0	0	517.78	2760	69.9	7.38	36.06
519.36	0	1.5	0	0	518.85	2760	39.1	4.1	18.64
520.35	0	1.5	0	0	519.85	2720	16.5	1.23	0
521.36	0	0	0	0	520.86	2680	12	0	9.44
522.35	0	0	0	0	521.85	2600	12	0	3.11
523.35	0	0	0	0	522.85	2560	9.8	0	5.11
524.35	0	0	0	0	523.85	2520	16.5	2.05	8.72
525.52	0	0	0	0	524.91	2440	12	1.64	5.83
526.56	0	0	0	0	526.06	2400	8.3	0	3.78
527.55	0	0	0	0	527.06	2360	9	0	4.11
528.55	0	0	0	0	528.06	2280	8.3	0	4.22
529.55	0	0	0	0	529.05	2240	8.3	0	3.17
530.56	0	0	0	0	530.06	2200	10.5	0	1.47
531.56	0	0	0	0	531.06	2120	9.8	0	1.83
532.75	0	0	0	0	532.18	2080	10.5	0	3.97
533.75	0	0	0	0	533.25	2000	9.8	0	4.03
534.75	0	0	0	0	534.25	1960	9.8	0	3.78
535.75	0	0	0	0	535.25	1880	9.8	0	3.5
536.75	0	0	0	0	536.25	1760	9.8	0	3.44
537.75	0	0.8	0	0	537.25	1720	33.1	6.56	18.11
538.78	0	2.3	0	0	538.25	1720	70.7	7.79	25.06
539.95	0	0.8	0	0	539.42	1720	53.4	5.74	16.83
540.95	0	0	0	0	540.44	1160	25.6	3.28	8.06
541.94	0	0	0	0	541.45	880	21.8	2.05	2.72
542.94	0	0	0	0	542.44	2240	9	1.23	5.25
543.94	0	0	0	0	543.45	2640	8.3	0	4.36
544.94	0	0	0	0	544.44	2320	8.3	0	4.17
546.02	0	0	0	0	545.44	2040	9.8	0	5.31
547.04	0	0	0	0	546.55	1560	12	0	6.42
548.04	0	0	0	0	547.54	1000	14.3	1.64	3.19
549.04	0	0	0	0	548.54	840	18	2.05	2.92
550.05	0	0	0	0	549.55	840	17.3	2.05	2.69
551.04	3.8	4.5	0	3	550.54	1440	51.9	5.74	14.19
552.04	3.8	4.5	0	3	551.54	1640	57.9	6.56	19.22
553.11	3	3.8	0	2.3	552.55	2840	97	10.66	58.36
554.14	3	3.8	0	2.3	553.64	3320	19.5	1.23	0.5
555.15	2.3	3.8	0	1.5	554.65	2400	55.6	6.56	28.08
556.15	0	0	0	0	555.65	2760	53.4	4.92	24.31
557.15	0	0	0	0	556.65	2920	36.1	3.69	19.22
558.14	0	0	0	0	557.64	2960	27.1	2.87	15.17
559.14	0	0	0	0	558.64	3000	27.8	3.28	16.39
560.3	0	0	0	0	559.7	3040	36.8	4.51	23.17
561.33	0	0	0	0	560.84	3160	43.6	4.51	26.61
562.34	0	0	0	0	561.85	3320	60.2	6.97	40.81
563.36	0	2.3	0	0	562.84	3440	23.3	1.23	0
564.44	0	0	0	0	563.94	3360	18.8	2.05	11.92
565.43	0	0	0	0	564.93	3280	15.8	1.23	0
566.44	0	2.3	0	0	565.93	1680	15	3.28	9.83
567.53	0	0	0	0	567	1720	12.8	1.64	5.11
568.53	0	0	0	0	568.03	1720	37.6	4.51	13.61
569.54	0	0	0	0	569.03	1760	47.4	4.92	16.39
570.53	0	0	0	0	570.03	1800	23.3	2.05	6.14
571.53	0	0	0	0	571.03	1800	11.3	1.64	4.19
572.54	0	0	0	0	572.03	1760	16.5	2.46	8.5
573.55	0	2.3	0	0	573.03	1760	43.6	5.74	17.97
574.63	0	2.3	0	0	574.1	1840	51.1	5.33	18.5
575.63	0	0	0	0	575.13	1920	50.4	5.74	18.72
576.63	0	0	0	0	576.14	1960	44.4	4.92	16.86
577.64	0	0	0	0	577.13	2000	44.4	4.92	17.19
578.63	0	2.3	0	0	578.15	2040	42.9	6.56	21.81
579.63	0	0	0	0	579.13	2080	47.4	4.92	19.44
580.67	0	0	0	0	580.13	2120	36.8	4.1	15.14
581.83	0	0	0	0	581.28	2160	36.8	4.1	14.89
582.85	0	0	0	0	582.33	2200	42.9	4.92	17.81
583.82	0	0	0	0	583.32	2200	28.6	3.28	11.53
584.82	0	2.3	0	0	584.33	2160	13.5	1.23	0.31
585.82	0	0	0	0	585.32	2080	12.8	0	3.61
586.82	0	0	0	0	586.32	2040	14.3	1.64	5.06
587.9	0	0	0	0	587.32	2080	18	2.05	6.39
588.93	0	0	0	0	588.43	2120	21.8	2.87	10.22
589.92	0	0	0	0	589.43	2080	12.8	1.64	5.06
590.92	0	0	0	0	590.42	2000	9.8	0	3.83
591.92	0	0	0	0	591.42	1720	9.8	0	2.75
592.92	0	0	0	0	592.42	1480	9.8	0	2.83
593.92	0	0	0	0	593.43	1280	9.8	1.23	2.64
595.1	0	0	0	0	594.48	1120	12.8	1.64	2.92
596.12	0	0	0	0	595.62	840	16.5	2.05	2.58
597.12	0	0	0	0	596.62	840	17.3	2.05	2.92
598.12	0	0	0	0	597.63	840	18	2.05	3
599.12	0	0	0	0	598.62	840	18	2.05	2.92
600.12	0	0	0	0	599.62	840	18	2.05	3
601.12	0	0	0	0	600.63	840	18	2.05	2.97
speedsix
Leon Cupra R 225
Oct 30, 2004
825
I did do some 4th gear pulls to the redline but methinks that wasn't the bit I pasted..
EDIT: I've pasted the end half of the file now which has 4th gear pulls (on my private race track officer).
Dom.
speedsix
Leon Cupra R 225
Oct 30, 2004
825
Ah I see. Will do some more when I can.
How fast is a cupra near the redline in 4th?
