the request is lean which is whats odd to me
I thought the two lambda values were pre and post cat, rather than actual vs. requested?
you need to be seeing 0.8xx under load... 0.9xx is showing lean not rich iirc..
id be looking at potential leaks in vac lines and cooler pipework
although your boost logs look ok. maf is ok for standard lcr.
your fuelling isnt causing any timing pull at all.
when were your plugs last done... fuel filter also
When I said MAP I meant the Mass air pressure sensor near the throttle body mate, these engines have both MAP and MAF to make things complicated lol, could be duff?
I'd try some injector cleaner, fuel filter and plugs first. Also check for splits in the inlet pipe that connects to the turbo inlet from the air filter.
It will be forced out maybe up to the sound deadening then onto the cam cover?
The breathers are under the inlet and, well, to the right of the cover.
It effects boost, so chances are it would run lean.
they are leaky injector seats....
this will cause a leak and will affect your fuel trims
could be the top injector seals also id change both to be sure
can check fuelling yes block 031.
you want to see 0.8xx under load. youve logged these already havent you
