Make sure they remove the manifold to replace the injector seats or the old threadlock falls down into the head.
Guest, New Stock alert: Premium CUPRA valve caps now available in the store ? Order now from the merchandise store
Slightly off topic, but if they're going to have to take the inlet manifold off anyway then they'll need a new gasket to put it back on right? If so, might I be as well (if I can afford it) getting something like a Newsouth Power Gasket or one of Bill's Phenolic gaskets to put on while they're at it? Do these really make any worthwhile difference?
I had mine RR'd last weekend and my standard LCR showed 206 Hp, 202 lb/ft (184 Hp at the wheels).
The guy said this was strange as the 1.8T 20v he has tested usually hold the power. He recommended new plugs. According to the SH, these were done 15,000 miles ago (recommended change at 40,000) so they should have plenty of life in them.
Any thing I should be looking out for? Relatively new to the LCR and a bit of a novice when it comes to this. What are the OEM plugs for a 2005 LCR?
Any help on this would be greatly appreciated.
Alright Ben, well I got the above stuff done a couple of weeks ago but not had a chance to get it logged yet, both me and the guy who kindly does VAGCOM help for me have been too busy to get it together. Hopefully will have some results soon, I'll post here as soon as.
Remind me, did you get yours sorted in the end? Did you manage to install a silicone TIP?
Saturday,26,January,2013,17:18:54
1ML 906 032 ,,1.8l R4/5VT 0001,
,Group A:,'003,,,,Group B:,'031,,,,Group C:, Not Running
,,RPM,Mass Flow,Load,Ign. Timing,,Lambda Factor,Lambda Factor,Bin. Bits,Bin. Bits,,,,,
,TIME,,,,,TIME,,,,,TIME,,,,
MARKER,STAMP, /min, g/s,%, °ATDC,STAMP,,,,,STAMP,,,,
,0.30,1240,20.58,58.0,11.3,0.00,0.828,0.953, , ,,,,,
,0.91,1360,24.83,63.9,12.8,0.60,0.961,0.961, , ,,,,,
,1.51,1480,26.11,68.6,13.5,1.21,0.969,0.953, , ,,,,,
,2.11,1640,30.53,74.9,13.5,1.82,0.945,0.953, , ,,,,,
,2.72,1760,35.08,80.8,13.5,2.42,0.945,0.953, , ,,,,,
,3.33,1920,39.17,83.9,13.5,3.03,0.953,0.953, , ,,,,,
,3.93,2080,47.03,87.5,11.3,3.63,0.961,0.953, , ,,,,,
,4.54,2280,57.08,90.6,11.3,4.23,0.945,0.953, , ,,,,,
,5.13,2480,68.78,94.1,12.0,4.84,0.945,0.953, , ,,,,,
,5.74,2720,91.83,96.9,8.3,5.44,0.938,0.953, , ,,,,,
,6.35,3000,130.31,100.0,3.8,6.05,0.961,0.953, , ,,,,,
,6.95,3400,126.56,100.0,5.3,6.65,0.961,0.953, , ,,,,,
,7.55,3720,142.64,100.0,7.5,7.25,0.930,0.953, , ,,,,,
,8.16,4040,150.44,100.0,9.8,7.85,0.945,0.953, , ,,,,,
,8.76,4360,157.72,100.0,12.0,8.46,0.938,0.953, , ,,,,,
,9.36,4680,166.86,100.0,10.5,9.06,0.969,0.953, , ,,,,,
,9.97,4960,171.33,100.0,9.8,9.67,0.961,0.953, , ,,,,,
,10.57,5200,186.97,100.0,12.0,10.27,0.945,0.953, , ,,,,,
,11.17,5440,192.86,100.0,12.8,10.87,0.961,0.953, , ,,,,,
,11.78,5680,196.19,99.6,12.0,11.48,0.945,0.953, , ,,,,,
,12.38,5880,194.94,100.0,12.0,12.08,0.945,0.953, , ,,,,,
,12.98,6080,197.14,100.0,13.5,12.68,0.984,0.953, , ,,,,,
,13.59,6240,198.50,100.0,17.3,13.29,0.922,0.953, , ,,,,,
,14.20,6440,198.75,100.0,18.8,13.89,0.922,0.922, , ,,,,,
,14.79,6600,196.53,99.6,17.3,14.49,0.852,0.860, , ,,,,,
,15.40,6760,193.08,100.0,18.0,15.10,0.867,0.821, , ,,,,,
