First time logging in LCR
jetsetjimbo
a.k.a James
Jun 12, 2005
630
J2 M5
Well after speaking to lots of you at Oulton I decided I needed VAG-COM.
Tried to do some logging tonight and got the figures below. I only did block 002 and group 005 (I know they shouldn't really be done at the same time now) also didn't do 115 and 118. Just wanted mass flow to start with...
Group A: '002
RPM Loa Inj. On Time Mass Flow
TIME
STAMP /min % ms g/s
0.39 2360 42.9 3.74 19 Part Throttle
1.3 2360 47.4 4.08 21.11 Part Throttle
2.3 2360 57.9 5.44 28.25 Part Throttle
3.2 2400 48.9 4.08 19.67 Part Throttle
4.11 2400 47.4 4.08 20.81 Part Throttle
5.12 2400 47.4 4.08 21.39 Part Throttle
6.13 2440 56.4 4.76 26.19 Part Throttle
7.03 2480 56.4 4.76 25.81 Part Throttle
7.94 2520 65.4 5.44 33.44 Enrich.
8.94 2640 112.8 10.54 65.72 Part Throttle
9.85 2920 143.6 13.6 78 Part Throttle
10.85 3160 140.6 12.92 86.31 Part Throttle
11.76 3440 141.4 13.26 93.14 Part Throttle
12.66 3720 143.6 13.6 102.28 Part Throttle
13.67 4000 141.4 13.6 107.58 Part Throttle
14.57 4240 142.9 14.28 114.81 Part Throttle
15.58 4480 141.4 13.94 122.03 Part Throttle
16.49 4720 138.3 13.94 125.47 Part Throttle
17.39 4920 143.6 14.28 134.31 Part Throttle
18.29 5160 145.1 14.62 140.86 Part Throttle
19.2 5360 145.9 14.28 150.39 Part Throttle
20.11 5560 145.9 14.62 155.75 Part Throttle
21.01 5760 145.9 14.62 159.78 Part Throttle
22.03 5960 141.4 14.62 160.56 Part Throttle
23.02 6120 135.3 13.26 159.19 Part Throttle
23.93 6240 139.8 13.94 161.64 Part Throttle
24.94 6400 131.6 12.92 161.08 Part Throttle
25.85 6560 68.4 5.1 100.64 Enrich.
Does the above look ok? 160 g/s seems to be about normal for a stock 210 LCR? The throttle bit seems weird as it was mashed to the floor (4th gear 2000-6500rpm) run or is it always like that?
I got the below at the end of a second shorter blast:
6400 133.8 13.94 165.75
I am also trying to diagnose a bit of hesitancy which occurs intermittantly between 2-3k (in varying places) since I had a Revo trial but you might know it didn't do it tonight.
Would the 115 and 118 blocks be better for that?
Also are you guys mainly using registered versions? I'm using 409 with the lead I have but it dosen't seem to want to do the full fault code scan without complaing about not being a full version.
Any help / advice would be greatly appreciated. I couldn't decide if this should be in here or the Leon board.
Feel
Veedubya 'velle
Jun 12, 2003
4,918
Midlands
MAF looks okay for a standard LCR. Don't know about the part throttle business (I don't log 002), but I would do a throttle body adapt just to be sure. There's instructions for doing this with vag-com on their site, or you can do the bonnet up thing I mentioned at Oulton.
Sometimes, at the end of a run when you lift off, you get a blip in the MAF reading, but I wouldn't discount a 165. For example, on mine, I usually see 210 and a little bit more, then occasionally see nearly 220 at the end of a run.
It's easier to see blips/dips if you graph it.
115/118 and 020 are the other blocks to look at, as well as 31 (air/fuel ratio) but that one doesn't mean much to me :shrug:
jetsetjimbo
a.k.a James
Jun 12, 2005
630
J2 M5
Cheers guys I'll give that a go. :)
Out of interest do need the fully paid up version of the software to do it that?
Also with the autoscan of the fault codes - should the shareware / unregistered version just do that?
jetsetjimbo
a.k.a James
Jun 12, 2005
630
J2 M5
Uwe@Ross-Tech said:
Indeed I was going to buy the ful offical vag-com interface but the distributor I was looking at has gone and the price of the basic thing seems to have gone up a fair bit in the last month!
Is the registration for the shareware automated? I.e can I do it over the weekend? Also can it be moved from machine to machine as many times as needed if the correct procedure is followed?
What happens if my HD dies and I can't get the de-activation code off the PC?
Uwe@Ross-Tech
392
www.Ross-Tech.com
There are a number of other distributors in the UK:
http://www.ross-tech.com/distributors.html#uk
And Ross-Tech ships to the UK as well.
There have been no pice increases, at least on our end.
No, the registration process is not automated. When registered to a particular PC (with a 3rd party "dumb" interface), it can be moved from machine to machine using the appropriate (see our FAQ page 5), but if you plan to change PC's often, you'll be much happier with a geniuine Ross-Tech interface with integrated dongle. Failed HDs will require a new code. This is generally not a problem if it doesn't happen too often and you're using the same PC.
-Uwe-
jetsetjimbo
a.k.a James
Jun 12, 2005
630
J2 M5
Thanks for that.
I agree I would be better off with the full thing but it's a little out of my reach at the moment. If I but the licence for use with the 3rd party lead at the moment and then upgrade to the full lot at a later date is the original licence refundable?
If so I assume the purchase would need to be made direct with Ross-tech rather than a UK distributor?
If I was to register this evening when could I expect the registration code? I was hoping to do some further logging this weekend...
Uwe@Ross-Tech
392
www.Ross-Tech.com
Yes, registered users with 3rd party interfaces can get full credit for the cost of the license they already own if/when they decide to upgrade on of our interfaces. But in order to receive that credit, you'll have to use our interface upgrade program, which is available only directly through us.
Timing really depends. Its' only ~11:30am here at the moment, so if you hurry up, we can probably still get it done for you for the weekend, but I won't make you any iron-clad guarantees. And Monday is a holiday here...
-Uwe-
jetsetjimbo
a.k.a James
Jun 12, 2005
630
J2 M5
Managed to scrounge an unused offical lead from a mate....
Been out for some more logging tonight....
Code:
Group A:	'115				Group B:	'118				Group C:	'002
	RPM	Load	Absolute Pres.	Absolute Pres.		RPM	Temperature	Load	Absolute Pres.		RPM	Load	Inj. On Time	Mass Flow
TIME					TIME					TIME
STAMP	 /min	%	 mbar	 mbar	STAMP	 /min	°C	%	 mbar	STAMP	 /min	%	 ms	 g/s
20.21	2560	60.2	990	1180	20.51	2560	24	0	1180	20.81	2560	31.6	2.72	10.64
21.12	2560	30.8	990	1070	21.42	2560	24	0	1050	21.72	2560	36.8	3.4	18
22.12	2560	48.9	990	1050	22.42	2600	24	0	1070	22.73	2600	48.1	4.42	23.89
23.03	2440	17.3	990	1080	23.33	2240	24	0	1050	23.63	2480	22.6	2.04	11.86
23.93	3320	30.8	990	1020	24.23	3160	25	0	1030	24.64	3200	33.8	3.06	21.97
24.94	3200	40.6	990	1040	25.24	3240	25	0	1060	25.54	3240	49.6	4.42	33.31
25.84	3280	57.9	990	1140	26.14	3320	24	0	1220	26.45	3400	78.2	7.14	52.56
26.75	3440	85.7	1270	1320	27.05	3520	24	1.6	1320	27.35	3640	92.5	8.5	65.36
27.65	3720	94.7	1390	1330	27.95	3800	23	59.2	1340	28.26	3920	129.3	11.56	118.19
28.56	4080	146.6	1760	1800	28.96	4240	22	62.4	1830	29.26	4400	151.1	14.96	126.39
29.56	4560	147.4	1780	1790	29.87	4680	21	62.4	1800	30.17	4840	143.6	13.94	134.69
30.47	5000	143.6	1780	1810	30.77	5120	22	62.4	1780	31.07	5240	143.6	14.28	144.28
31.47	5440	148.1	1810	1770	31.78	5560	23	64.3	1850	32.08	5680	146.6	14.62	159.11
32.38	5800	145.9	1790	1820	32.69	5920	24	62	1820	32.98	6040	148.1	14.96	165.19
33.29	6160	133.8	1730	1800	33.6	6280	24	61.2	1750	33.9	6360	132.3	12.92	164.64
34.2	6480	139.1	1690	1740	34.49	6560	26	55.3	1740	34.8	6360	12	1.02	2.19
This was done ~2k to 6.5k in 4th on a flat road.
Mass flow looks good. I'm not sure about the boost figures but the actual seems to be meeting the requested though.
N75 duty looks very low?
I did the bonet up throttle body reset but the 'operating condition' field in 005 stays on part throttle when the throttle is pinned. Is this limited by the ECU independantly to how far the pedel is physically depressed?
Uwe@Ross-Tech
392
www.Ross-Tech.com
Interesting. You've got practically no requested boost until ~3500 rpm. Now I don't know the 210 hp engine well at all (was never imported here), but this does not seem normal for a 1.8T with a stock turbo (even a K04). It seems to me it should be asking for boost much earlier than that. Perhaps someone with the same engine with an umolested ECU could confirm that...?
-Uwe-
jetsetjimbo
a.k.a James
Jun 12, 2005
630
J2 M5
To be honest I'm not sure I was on full throttle until 3k ish but I was expecting to see it come on boost eariler.
I do have these sort of figures from other points in the log:
76.63 2760 87.2 1240 1310
so it will request more boost at sub 3k...
Feel
Veedubya 'velle
Jun 12, 2003
4,918
Midlands
I've never logged a standard LCR, but if your's is meeting requested, then I wouldn't worry about your N75 figures.
jetsetjimbo
a.k.a James
Jun 12, 2005
630
J2 M5
Cool - will give it another go from 1500 rpm.
Going to do some more today to see if I can track down the cause of tge surging.
Also going to put the DV stpete gave me on there.
Yak
Horned
Oct 18, 2002
263
UK
James,
Any update on this issue? I'm having similar issues inc late boost (after 3.5K)and have changed:
MAF, N75, Spark plugs, DV, Cleaned Throttle body and ran TBA, all with no joy.
I have a theory, but before I make myself sound stupid, how old is your LCR?
Yak
