(Leon) I just cut a section of fuel hose out just before my fuel rail and fitted my Walbro in the gap. I took a signal wire off the fuel pump relay to a new relay to power it.
I was going to stick mine by the filter - until I had a good look at the oem plastic pipe fittings and decided they were going to be a bitch to splice into.
here is my pump. one end is a very big push on the other is either a normal banjo bolt as seen installed or there is the option of the male banjo (just in front of pump)
The signal wire is the Green/white wire that goes to the fuel pump relay. Give me your email address and i will email the full wiring diagram over matey.
merlinmotorsport sold me a 8mm-12mm reducer that does the job perfect. i also picked up some 13mm id fuel line. not sure if its strong enough tho !? may collapse under suction!?
flapper, would you have any 12-13mm id hose? thank you please!!??
