simonj
69
I bought one of those alloy strut braces for Germany and thinking of fitting it this weekend, I'm guessing I'll need 4 x M10 bolts about 40mm long?, 8 washers & 4 nylock nuts, whats the best type to buy stainlees steel? any where I can get them cheap?
I used M8 riv-nuts, M8 Stainless bolts, Stainless flat washers and Stainless spring washers.
I did'nt use the setting tool, I just drilled some 11mm holes and the riv-nuts went in with a gentle tap. There was enough of an interference fit for the nuts to grip the holes and as soon as they start to pull up you're away. No problems at all and if you need to remove the strutbrace at any time its very easy.
I personally wouldn't trust them for anything structual either but thats just my opinion.
Seen a hell of a lot of these ripped out in light accident conditions.
We used to use rivnuts at work of varying sizes and inserted by gun
If you can get the mandrel and anvil you can rig up a manual version
Everyone of these were torque tested and not too many failed but when they did they ruined parts and were difficult to remove
I would not use rivnuts to attach a strut brace
Jonny if you do remove your brace be careful as with the bolt tightly into rivnut and rivnut not correctly torqued you may spin rivnut instead of releasing the bolt( seen it happen a lot)
Also the guns we had ran on 7 bar air supply and used steel inserts, (stainless will require slightly higher pressure) but using M12 with reasonably short stroke you needed full pressure to correctly deform them
Just something to think about
I've never used rivnuts before and going by the general opinion even though they seem easier to use I'll go with nuts & botls, seeing as the strut brace I have only has 2 holes would I be better with M10 or do you think M8 would be OK
