jcborden
I've been trying to isolate an annoying rattle which mainly happens over bumps and general rough surfaces. Last night I found that the front of the dash where it meets the windscreen, particularly on the passenger side has a bit of movement and seems to be causing most of it.
If I bang on the dash I can hear it and see that the front doesn't seem to be well enough supported, so tested squashing some rubber anti slip matting between the dash and windscreen - this has certainly improved things, so I will experiment a bit more.
Has anyone else found this, or is your dashboard a little flexible in this area. What I don't know is how the dash is supported or attached at the front...
