rossh13
Right guys driving home today and my glowPlug light is flashing and the traction control light is on! Pulled over and checked both my brakelights are out???
The led third brake light is still working?
Changed the bulb and there still out looks like there's no power to them!
Problems
I fitted hids about 3 months ago could it b them?
Got the side fixed at a bodyshop cause someone ran into the side of my car when it was parked up and drove away?
Most likely to be a faulty break light switch - not expensive don't worry. It happened to my Dad's ibiza - VAGCOM it to be sure.
Don't have vagcom! Only other thing I done was disconect the battery if that would of triggered a problem?
Am beginning to think the bodyshop has cut or damaged a wire during repair?
Brakelight switch could b possible but wouldn't that mean the third brakelight would also not work?
Had a similar problem on my FR Tdi recently, ended up changing the brake pedal switch (about £7) and then the two bulbs.
It's very simple to do too, 10-15 mins max.
No more warning lights now......
