ZRZ
284
Hertfordshire
Hello,
Suspecting that my DMF is on its way out already! Something which isn't covered by the garage I bough the car offs warranty :cry:
I've found a complete SACHS kit including flywheel and clutch and just wanted to first check that this part will be correct, and second if anybody had any difference recommendations. I'm not sure what condition my clutch is in but it doesn't slip at all, just the flywheel is vibrating through the clutch pedal and making a noise when cold and vibrations at idle.
GSF Car Parts Part Number: 022VG0740
Here is the link to the kit: https://www.gsfcarparts.com/022vg0740
or... Would you trust a kit as being genuine from eBay? They seem to have sold a lot of them. http://www.ebay.co.uk/itm/VW-Group-...l:Leon&hash=item2eebd5e6ba:g:PFcAAOSwZ1lWdcmJ
All help is appreciated!
Yep all looks right. Send them your reg than can check for you. Thats a real good price with a two year warrenty. Dont forget to order new flywheel/clutch cover bolts too
That's why I was a bit weary of the eBay one because bearing in mind a DMF is normally around £400 alone yet they're selling the whole lot for just over £300.
I think it comes with the bolts too!
GSF have a 45% off at the moment, WOW45 at the checkout.
If that doesn't work Euro car parts have 30% off this weekend too.
Just tried the 45% code for GSF and it doesn't work. But code GSF30 does work.
Goes from £689.46 to £482.62.
Hope this helps
Hope this helps
Thanks for the info bud, I did find a 47% off code also... WKEND47
In two minds in deciding whether to go for a GSF SACHS kit or go for one off eBay for £310 (still SACHS & two year warranty).
Not going to be doing the work immediately, going to wait and see if the noises get worse before i fork out £310+ in parts and who knows how much a garage will charge to fit!
Yeah I got a full LUK kit from Euro car parts about a year ago for £350 including the flywheel. I thought my clutch was slipping but after I changed my brakes it stopped which was very weird! Its still in the cupboard for when it does go!
At least if you get it from GSF it should be the real deal. I'm always weary about getting stuff like that from eBay unless it's a decent company. For instance I bought my exhaust from eBay but the seller was larkspeed.
