no i took it to AMD Essex in Lakeside and paid £400 and as im aware they do custom remap to match the performance of the parts can take, its superb. i had a full tank and my mate in the car and he timed me from 0-60 obviously its not dead accurate but more than once it was hittin 5.5-6.0 and as standard they say its 7.7 so cant complain
So its a full custom map for £400 not just a before and after run with a 15min remap?
Sorry for the questions I'm getting mine done soon and AMD is closer to me than most.
eeeeerrrrrrrrmmmmmmmm, dunno i left my car with them and i went into lakeside and went back a few hours later and they had only just finished it, but you do get a before and after sheet
285ft lb is not bad !.. im on about 200 and 245ftlb at the mo just with a milltek catback and amd stage 1. im guessing you have fmic, 4bar, new injectors etc ?
237bhp will be a custom map, generic pull 215 usually.
237 will need supporting mods, larger dp and cat, tip, induction and a uprated dv to hold the boost.
yeah got all those but no cat, the old one was rattling so had it taken out and replaced with piper down pipe and de-cat.
I've looked into this, AmD will check the car first to see if there are any problems and do a power run. They will then map it on the rollers and on the road and finally do a power run on the dyno to give you the final figures.
