paully
18
I have a 2003 Cordoba TDI and I know we are in the middle of winter and all that but it has started to fog up inside as soon as you get in, as a result you have to run the climate control all the time just to keep the glass clear. I dont recall any such problems last winter with it so has anyone any ideas as to a fault or is it just one of those things???
Thanks so far...plot thickens though, have checked re the carpets and are snuff dry....hmm:think:
My 03 Cordoba does the same!
But i've noticed that the climate control doesn't seem to be working properly it doesn't seem to get very cold like it used to, and that means an expensive visit to the dealers.
Maybe yours is the same the climatronic system is well known for problems!
Geoff
Thanks for that, maybe its one of the winter vagaries of the later Cordobas...sorry re your climate control, but if its a visit to the dealer it will be expensive....so far so good with mine though...thanks
Check the clutch cable gromit prone to falling out letting moisture down the cable and making car mist up even freeze on inside the girlfriends ibiza does it got a new gromit when i noticed it was missing so fingers crossed will sort the problem.
Less than £3 to.
Thanks for the tips guys, although I`ve been told, by the dealers, that the 03 type Cordys have the hydraulic clutches and so no cables, but will check again..thanks
