May 13, 2007
1,017
Denmark
Just had a MAP change and now I can switch between the stock and revo map.
A the moment I have some problems with the car, så the setting is stock, but havent changed my spring(dont have a green). Will my test runs/log be spolied by the yellow spring?
And how will it affect the car?
With less boost I think the spring will open less (or not at all) when coming off boost. You might be able to hear the turbo stalling as the charge air is forced back across it.
I don't know specifics but the yellow spring is only recommended for 15-20psi boost I think and the stock map gives a little less than that.
All in all, not likely to be good for the turbo long term but for a short spell I shouldn't think it will do much damage.
