just get yourself a forge TIP pipe if your going for OEM look than stick to black
one of the most important pipes to change
It does collapse on hi boost ;) mine did on 17 psi go for blue but I wouldn't bother with the forge (altho dan will tell you otherwise) there so overpriced and plenty of other companies do the same kits at half the price ;)
I got a set for 80 something from eBay from demon sport, good imo. I did the tb hose at the weekend and it roars now
i aint got a pic but you can only see three pipes anyway. the two that come off the turbo and to the dv. and the big hose that comes to the tb. ones under a heat wrap thing off the turbo, and i believe the other one which is about 3 inch goes somewhere you cant see it lol
