hutchy125
I dont want a refund i want it to work after payin the money and waitin two weeks to get it.
where is this group buy?? am interested in getting one of these. have had a look in the forge section but am unable to find it
Also depends how you drive the car, window's down load it up on a hill and just let off the throttle not using the clutch and see if you can hear anything. People tend to let of the throttle and slowly depress the clutch in which the boost levels drop so not much noise.
also i have noticed tHAt the small vacuUm hose that goes into the dump valve is streTched and bent, could this be my problem?and if so, wHere can i get more of the rubBer tube ? Also, is the dump valve meAnt to get roastinG hot ?
