Just purchased and fitted the forge spacer to my 1.4TSI Fr and every so often the engine management lights flash on and off?? just wondering if anyone else has had this issue or if its maybe a problem with my car?
You need to get the fault codes checked before guessing. It can't be a fault with the spacer itself only the fitting of it if it's not sealed correctly.
I've had the forge spacer fitted but that problem was already happening with my car previously. As techie said you'll want to hook it up to get the fault code
