Whilst you are sat on the M25 I'm busy pounding the lengths and breadths of the UK, covering quite a few miles in both diesels and petrols so my comments about road types and driving conditions still apply.
How many miles have you done in a 184 Fr? (you know, the car the OP was asking about.....)
Hi All,
I recently bought a FR 184 DSG to replace my ageing Mk. 2 PD140.
One thing I've noticed is that the fuel economy is terrible. Since I've owned it I've only seen it go above 50 mpg once, and that was because I was driving like a saint (60 mpg on a motorway run) to see if it could be done.
Typically on my 20 mile commute (mostly motorway) I'm seeing low 40's. On a longer run (50 miles) it got to 48 mpg.
The majority of the time I'm getting 42/43mpg, and I'm not driving it fast/aggressively, and in "eco" mode.
Is this normal? Is it because it's a DSG? Would be interested in seeing if anyone else has these low numbers?
On my previous car I used Millers EcoMax as a fuel additive but not sure this made any difference. As the car does more miles, am I likely to see an economy improvement?
The car is a 2015 Leon FR ST, DSG, with around 7000 miles on the clock.
Thanks.
None, thankfully. I will say this again, but only once as I'm sunning myself on a beach and this, much like all mpg threads , is getting boring. I was.pointing out that modern diesels are not as economical on short journeys as older ones were. Power output, type of car, trim level notwithstanding. I'll leave you to the joys of the M4/25. I'm off for a beer. That sort of consumption I like. Tara a bit as we say in God's country.![]()
Change of right foot needed.
I easily get over 70mpg out of mine on a motorway run and on a short run to my son's house just 28 miles away on A and B roads I get 52mpg and I can get this up to 56mpg if I drive like Miss Daisy. Alternatively, I once did the run in 40 minutes early in the morning in sport mode and letting the turbo ride up to 4000 revs on each change and only returned 42mpg.
Check you tyre pressures, empty any excess weight out of your boot, change up under 1500 rpm, keep the revs below 2000 rpm at all times, never use more than 50% throttle, don't use your brakes, anticipate and allow the velocity to shed via friction, aim to pick gaps on roundabouts so you don't need to stop then start. Consider going on some advanced drivers courses, they make a huge difference to how far ahead you are planning and anticipating. I have done 34K in mine and averaging 58mpg long term with my front tyres doing 19k before hitting 1.6mm, rears are about ready for change and I still have over 50% of my brake pads left at the front with the rears almost complete. Previously I had a BMW 20L D and got 35k out of the rear tyres on a RWD car and at 75k I swapped it, still with original brake pads all round. That car averaged 58.5mpg over the full 75K.
Lastly get rid of the Techno, Drum and Bass and house music and listen to Classic FM
That not that good.
i drive weekly from somerset to Portsmouth witch is 90 miles i get anywhere from 51mpg to 59mpg.
and i have a bit of a heavy foot if you know what i mean. lol
what i would do is run some redex though your fuel system every few thousand miles, thats what i do and it works good.
well i get around the 600 miles per tank thats only a few miles short of old vx insignia and that had a bigger tank.I mentioned to the salesman and all he had to say was you must drive in sport more than eco. Eco makes it worse.
It was well below 50mpg, until I did a few engergitic miles which added nearly 8mpg and quite a few miles to the range.
I do miss my golf because the Leon has a smaller fuel tank too, now I travel further to work as well.
48mpg on a 380 mile run
