FR TDI Drop link replaced
Mar 26, 2007
713
Norn Iron
Just a heads up. Had a knocking, from front passenger side, turns out the drop link needed replaced - at only 44k!
Anyhoo, replaced under warranty incase anyone has similar problems ;)
rosco07
68
Hi, was it intermittent? i.e. did the noise go away after a few miles once the car has warmed up? I have a very similar problem, been in the dealers 3 times in the last 12 months and it NEVER makes the noise[:@] even when kept overnight. It is noticible on rough/uneven/bumpy ground. My car is 07 with 22K but this noise has been present on and off from 9K.
Any advice will be much appreciated!
seremotors
Dave the Parts Manager
Mar 11, 2008
12,507
9
Belfast UK
www.seatcupra.net
I would check engine mounts - a cold engine (especially diesel) vibrates a LOT more when cold and any wear in an engine mount rubber would be more noticeable. Just a thought . . .
Mar 26, 2007
713
Norn Iron
Nope, noise was always there - though not on flat motorway ground obviously, but over any speed bumps or potholes. ;)
