Hi thier I bought one of eBay but the led bayonet is a lot thinner than the reverse filament bulb in the car,is the one yu purchased the same as the one on the car and fits straight in as a replacement,the one I got can fit in the bulb holder on the car?
Got a led bulb for reverse light on my seat leon fr 184 2014 plate,the bayonet I'd a lot smaller than the filament bulb in the tailgate, can somebody please help with a solution.
the Cree LED I have fits straight in, no hassle. Its the same as the Mk2 reversing light.
Does anyone know if the Estate is the same as the 5 door?
Unsure, I've got a 5 DR hatchback and used the following:
http://www.ebay.co.uk/itm/261169683340
Which produces at daylight:
Very simple to fit the handbook has most of the details in:
  1. Lift the boot
  2. On the left hand side there's a cover, slide it to the left towards the end of the boot
  3. Push inwards the two clips (detailed within the handbook) and pull the black unit down, to do so I used the cable as you don't need to pull hard
  4. Remove the black holder from the light housing and locate the clear bulb
  5. Depress and twist the bulb (think bayonet fitting) and it'll pop out
  6. Replace bulb
  7. Refit into housing and clip back in :)
