FR wheels DO NOT fit over Porsche calipers
bruceR
2,576
665
Monifieth, Dundee
I have tried to fit a set of Porsche calipers, carriers and 312mm Ultramax discs to me FR TDI, thought I would be smart and trial fit them along with the wheel to find that the original FR wheels DO NOT fit over Porsche calipes :censored:
I had searched on here prior to buying / fitting and although some people say they will fit without spacers I can confirm do they f:ban:k.
So it back to the drawing board to find some spacers..............
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
put up the full spec and wheel type and size for reference then
might be where the issue is
bruceR
2,576
665
Monifieth, Dundee
Sorry for the delay guys.....
Calipers are Porsche Boxster rears (similar to 996) - 170quid ebay
Carriers / hoses from Dave Brown - about 160quid IIRC
Pads are DS2500 to suit calipers - 125quid from Badger Bill
Discs are EBC Ultramax 312mm - 161quid from Larkspeed
DOT 4 oil - 12quid
Plus:
10mm Forge spacers from Awesome - 62quid (no member discount though :cry:)
10mm longer wheel bolts from pcs-uk - 22quid for 10bolts
when the spacers & bolts arrive I will get these fitted and post some pics for you all....
james walker
cooling is the key people
May 24, 2007
5,121
retford notts
i fitted 996 rears on 18 inch inovit cts, perfect(tight) fit
as said spacers will cure this for you, measure the distance they dont clear by and use spacers to suit.
are they boxster rears or boxster s?
some boxster rears dont fit on 312x25mm discs?
spawns3
DOT 4 oil - 12quid
Plus:
Hi there , i have the rear porsche boxter S calipers , and i want to put it in audi a3 PD 130cv , where i can find the brackets for it ? I want to use the 312/25mm rotors.
