stornolad
Hi guys - got a 55 plate fr tdi, only had it for 5 days and love it. Not sure if i'm doing something wrong or is there a minor fault with the fog lights.:confused:
When i turn on the sidelights or dipped lights the front fog lights come on too.
When i half pull the lights switch the rear fog lights come on.
When i fully pull out the lights switch nothing additional happens.
I thought the half pull was to activate the front fog lights but it seems they come on anyway and there's no way of getting them off! On the 'brightside' i guess, at least they work!
Is this normal?
Do the front fogs come on with the side lights as standard?
fogs on mine dont. i CAN put them on with sidelights but would require turning one clikc and pulling out one click too.
illegal to be used unless their foggy aswel.
The switch:
turn one click for side lights
turn two clicks for main beam + sides
Pull one click for front fogs
Pull Two clicks for front + rear fogs.
my guess is someone has played with the wiring?
The switch:
Thanks for that - the way you described the lights sequence is exactly what i thought from reading the manual! Another minor problem then as well as AIR MASS LOW INPUT & COOLANT TEMP SENSOR CIRCUIT HIGH - ta for the help, much appreciated!
Incase anyone else has this daft problem, when the garage took of the area under the dash to replace my brake switch, they must've been a bit rough when replacing the under dash area & the contacts for my fog lights weren't right, which caused my fogs to come on with the normal lights!
My Leon has the same issue. When I turn the light switch the front fog lights lit up, too.
Yesterday I took it off and disassemble it but I couldn't find the problem.
One of the metal plates was darker than the others but still it looked okay. I've also found that when I turn the switch different plates pop up, but when I pull the switch none of them was popping off. Has someone dealt with this issue before?
When opened the switch looks like this:
Unfortunately I'm located outside UK.
If you have something in mind please share. I would appreciate it very much.
Thank you!
