mine does this since we lowered it last weekend goinig to check evrything we took off is still tight
Guest, 🎅🎄Looking for a stocking filler idea? Why not treat yourself or a loved one to our high quality CUPRA or SEAT valve caps. Order now from the merchandise store
As the suspension arms come down for the left and right wheels there are 2x subframe bolts up threw the arms. You will need it up on a ramp too tighten these ones up
And a long socket adaptor around 60 nm torque
If you look in the come mk2 faults pages you will find a video.
I will try and post some pics
I rechecked my subframe bolts today.. all torqued up to spec and I also took off ARB drop links to rule them out. It still knocks.
Hope I get to the bottom of it.
What have you torqued the sub frame bolts to? I tried taking off the drop links but no difference either!
80NM .. Mine sounds like something is really loose.. definitely not the subframe... it doesn't knock when turning steering wheel whilst stationary, only when going over bumps in the road.
Same as mine
