'corroded to excess' would probably be a fail. Mine were "corroded but not seriously weakened" which is code for "you might have to do something next year". The rear suspension doesn't look too good either. It's now a 13 year old car, which was never garaged only washed a handful of times (I bought it new) and there's a lot of salt on the roads in winter up here.
I've got a year to keep running it and see what goes wrong before next MOT, but the problems are starting to happen all too regularly now after years of good reliabilty.
I've just noticed a clicking when I release the brakes - it's coming from the rear load balancing valve - Haynes suggest it's adjustable but doesn't seem to give measurements or settings. Doesn't seem too cause any problems, just annoying now I've noticed it.
There's getting to be a list of things that need attention:
Power steering pipes to the rack corroded was an advisory
Handbrake just scraped through again, mechanism on one caliper probably knackered, need a new caliper.
Usual rear disc corrosion (I was going to replace those before this MOT but was waiting to see if caliper passed)
Radiator bodged with sealant. hard cooling pipe around engine also bodged.
When looking at balance valve, brake pipes don't look too good around there, probably need replacing next year.
Body and floor still seems sound enough though (I found a coachbuilder who did a lead filler repair to rear arches a few years ago)
If nothing else goes wrong before next year I'd probably do the subframe, if there are a lot more problems it might be time to call it a day.
I'll probably get a pre-MOT check done a few months before it's due so I can decide.
