Fuel Pressure Regulator seems to be wrong 4.0bar - Runs rich
ibiza1.8t-cupra
53
20
Car 1.8t Ibiza cupra 2004 180bhp
Getting rich fuel trims
idle -0.4%
run -7.8%
Looked at the FPR Fuel Pressure Regulator it says 4.0 bar part no 0280160575
Should it not be 3.0 bar for a stock 1.8t part no 037133035C
If anyone knows what their 1.8T FPR has?
Woody_72
502
253
Northwest England
Given that a normally aspirated petrol car normally runs a fuel rail pressure of 35-50 psi, 4 BAR (roughly 58psi) doesn't sound surprising at all.
ibiza1.8t-cupra
53
20
Thanks, do you think I should swap it for a 3 bar, as it's running rich, previous owner perhaps swapped it to 4 by mistske?
mishawel
51
7
Yes
First make sure the car is stock 100%
And I really doubt the previous owner has made a mistake, the 4 bar regulator comes in a few specific cars, and has nothing to do with the ibiza.
So make sure it is complety stock, if it is, just throw in the 3 bar regulator.
ibiza1.8t-cupra
53
20
I don't have a 3 bar so would need to buy one, just wondering if that could cause the rich running. It all looks stock. Not sure now if it it came with 4 bar as it's a VAG one
mishawel
51
7
Yes it could cause it to run rich.
The ibiza never came with 4 bar FPR.
ibiza1.8t-cupra
53
20
Just put in an second hand, VW 3.0 bar 037133035C FPR
Then reset the fuel trims in vcds
WOW, so much more power than with the 4 bar, 30% more, I would guess.
It now lights up the tyres in 1st, 2nd and 3rd gears, it's crazy fun to drive it again, even got the back out a little on a bend I was going so much faster, before it would bearely spin in 1st lol.
Thanks, so much for all your excellent advice on this, I would have never thought the wrong FPR could rob you of so much power.
I will report back on new fuel trims in a week or so.
ibiza1.8t-cupra
53
20
Checked Fuel trims today, they look much better
idle -0.9%
run +4.7%
So added together +3.8% lean, that seems well within specs.
Before it was around -8.2% to -9.8% rich, when added together.
