Full beam electronic issue
Jun 19, 2023
In the last month or so, full beam has stopped working when the stick is pushed forwards for constant full beam, and the associated light on the dash stays dark. BUT if I pull back the stock to flash, this does work and the full beam light on the dash lights up too.
Anyone else had this issue / knows where to look?
Jun 19, 2023
Update, If I remove fuse 14 - details below, I get the reverse functionality. Full beams work when stick is engaged forward but you can't flash by pulling back.
Removing ignition key, diagnostics, headlight lever (flashers), switching on dipped /side beams (rotating lights)
