Cupra306Form
136
92
Hi, Just fitted a pair of gas lift struts for the bonnet. Got em from Ali Express
£26.55 inc delivery.
Came with the fixings, just needed a spray of grease on all fastenings. The car is already drilled and a tapped thread ready for them, but the hole is covered with a small black rubberised sticker. You simply unbolt the colour painted upper fastening bolt on the bonnet and insert the supplied ball joint bracket, then re-attach for the top fixing. (12mm nut)
The lower fastening as I said, remove the sticker, put fastening in and tighten - lower nut 10mm, upper is 12mm. Snap on gas struts and test.
On the link someone has posted pics of the job done if you want to see result.
I wish I'd gone for the red to match car colour, but then again how often is the bonnet open!!
Reactions: Tripletrouble
You can get them from Amazon as well with next day delivery but at £39.
hey, new here so looking around as i just got my Formentor. Saw this. Looks like quite a cool mod. Found another thread as well.
I saw this one on both Amazon and AliExpress as well. Curious to your experience: did you damage something inside? How are they? Easy to open/close? :D
Work great, still functioning, good simple mod. No damage caused, and I always put a spray of Rustoleum rust killer spray on stuff I fit.
Reactions: krmzl
Hi,
1 year later, they're still working good.
It only require a bit "load" to close the bonnet properly, in order it becomes properly latched.
The bonnet's own weight is not enough to close efficiently.
thx! may get it when i start modifying it. Noticed the Racingline and Forge have both compatible air intake and Forge has a nice blow off valve. Will be fun combination.
Thanks gents! :)
Appreciate the tip, ordered. These are the small mods I like tinkering around with before going too crazy.
I recently installed some paddle shifter extensions from Ali Express as I was taught to drive with my hands at 2 and 10, rather than 3 and 9. Not perfect but pretty darn good for £12/AUD$25 delivered: https://vi.aliexpress.com/item/1005006138643773.html
The copper colour is a very close match to the Cupra accents. The finish is 8/10 decent. Snug fitment. They are a bit chunky, I would prefer something slimmer but the other options mostly have sticker backings for now.
Reactions: krmzl
In terms of paddle shifters I didn't want those enlarged one, but rather a different one which has a clicky switch. I found one on the internet after chatting with someone who has this installed in his VZ5: https://www.tddmotors.com/products/...s3-s4-s5-sq5-sq7-sq8-rs1-rs2-rs3-rs4-rs5-rsq5
Reactions: VEDI
I like the look of some of those options a lot. I think that is a solid plan to opt for a full replacement, will give it a whirl down the track.
Reactions: krmzl
