For refrence
020
6 Speed, mechanical clutch
Code Vehicle 1st 2nd 3rd 4th 5th Final 1
GC 4 speed up to '80 3.45 1.94 1.29 0.97 N/A 3.89
GC,GN 4 speed from '81 3.45 1.94 1.28 0.91 N/A 3.89
GP,GL 3+E from '81 3.45 1.75 1.06 0.71 N/A 3.89
GY 3+E Pickup 3.45 1.75 1.06 0.71 N/A 4.17
FO 11/'78-5/'79 3.45 1.94 1.29 0.97 0.76 3.89
FF,FN,FH Up to 07/'80 3.45 1.94 1.29 0.97 0.76 3.89
FF,FN,FH,FJ From '81 3.45 1.94 1.29 0.91 0.71 3.89
FM,FD,FK Close Ratio 3.45 2.12 1.44 1.13 0.91 3.89
6G Euro 8/'82-7/'83 3.45 1.94 1.29 1.29 0.91 3.65
7G Close Ratio, Euro 8/'82-7/'83 3.45 2.12 1.44 1.13 0.91 3.65
2H Close Ratio '83 GTI 3.45 2.12 1.44 1.13 0.91 3.94
4S,AOP,AGS '86-'90 1.6L Diesel 3.45 1.94 1.29 0.91 0.75 3.94
4T,8A Euro From 8/'83 3.45 1.94 1.29 0.91 0.75 3.67
7A From 8/'83 3.45 1.94 1.29 0.91 0.71 3.94
4K Close Ratio 3.45 2.12 1.44 1.13 0.89 3.94
4Y Close Ratio 1.8L 8v 3.45 2.12 1.44 1.13 0.89 3.67
9A,AEN,ACD Close Ratio '85-'89 3.45 2.12 1.44 1.13 0.89 3.67
ACH '85 1.6L Diesel 3.45 1.94 1.37 1.03 0.75 3.94
AGB,2Y Close Ratio,16V 3.45 2.12 1.44 1.13 0.91 3.67
ACN,AON,ASF,ACL 1.8L 8V 3.45 1.94 1.37 1.03 0.75 3.67
AUG,DGF,DGT 1.8L 8V '90-'93 3.45 1.94 1.44 1.13 0.89 3.67
AWY '90 Diesel 3.45 1.94 1.44 1.13 0.89 3.94
AVX 1.6L TDI ECO 3.45 1.94 1.29 0.91 0.75 4.25
CHB,APW,DFN From '93 1.8L 3.45 1.94 1.37 1.03 0.85 3.67
CHD,DFP,ATH From '93 1.9L TD 75hp 3.45 1.94 1.28 0.91 0.75 3.67
CHE,DFQ,DGD,AMC From '93 115hp, Large input shaft 3.45 1.94 1.28 0.97 0.80 3.67
02A
5 Speed, hydro clutch
AGC Corrado 1.8l 16v 3.778 2.105 1.345 0.971 0.795 3.944
AGK Corrado VR6 3.778 2.118 1.458 1.034 0.838 3.389
ASD Passat 16v 3.300 1.944 1.308 0.971 0.717 3.944
ATA Corrado G60 3.778 2.105 1.345 0.971 0.795 3.684
ATB Corrado G60 3.778 2.105 1.345 0.971 0.795 3.450
AYL,AYK Corrado G60, Passat 16v 3.778 2.118 1.429 1.029 0.837 3.684
AYN Corrado G60 3.778 2.118 1.345 0.971 0.756 3.684
CAW Corrado 3.778 2.118 1.458 1.034 0.838 3.647
CBA Corrado G60 3.778 2.118 1.360 0.967 0.769 3.647
CES Corrado 2.01 16v 3.778 2.118 1.429 1.029 0.837 3.684
CGY Corrado 2.01 16v, Passat 3.778 2.118 1.458 1.029 0.837 3.684
CHA Passat TDi 3.778 2.118 1.360 0.917 0.717 3.944
CDM Corrado VR6 3.300 1.944 1.308 1.034 0.838 3.647
CD/ Seat Toledo 2.0l 16v 3.300 1.944 1.308 1.029 0.837 3.684
CHN, CCM Corrado VR6, Golf/Jetta III 3.300 1.944 1.308 1.034 0.838 3.389
CNL Passat 2.0l 8v 3.778 2.118 1.458 1.029 0.837 3.684
02J
EDT
Seat Ibiza Cupra 1.8 20v 3.300 1.944 1.308 1.029 0.837 3.389
EKW
Seat Ibiza Cupra 1.9 Tdi 3.778 2.063 1.348 0.967 0.744 3.158
EBD Mk4 Golf 1.8T (AGU engine) 3.300 1.944 1.308 1.029 0.837 4.235
ENJ Mk4 Golf 1.8T (2000) 3.300 1.944 1.308 1.029 0.837 3.684
EHA 1.8T (AWP 180bhp) 3.300 1.944 1.308 1.029 0.837 3.824
CZM 2.0L Beetle '98 3.300 1.944 1.308 1.029 0.837 4.235
DQY TDI Beetle, Golf/Jetta IV 3.778 2.118 1.360 0.971 0.756 3.389
EGD 1.8T Beetle '99 3.300 1.944 1.308 1.029 0.837 3.938
DZQ,EBP,EGT,EKG 2.0L Beetle,Golf/Jetta IV 3.778 2.118 1.360 1.029 0.837 4.235
EKH,EMS,EZK,FBV 2.0L Golf/Jetta IV 3.778 2.118 1.360 1.029 0.837 4.235
EBJ,EGR TDI Beetle, Golf/Jetta IV 3.778 2.118 1.360 0.971 0.756 3.389
EBQ,EMT 1.8T Beetle,Golf/Jetta IV 3.300 1.944 1.308 1.029 0.837 3.938
EGQ,FBW 2000-up 1.8T Golf/Jetta IV 3.300 1.944 1.308 1.029 0.837 3.938
DZC,EHC,EGF VR6 Golf/Jetta IV 3.625 2.071 1.474 1.038 0.844 3.389
EWW,FBY,FCF VR6 Golf/Jetta IV 3.625 2.071 1.474 1.038 0.844 3.389
02M
6 Speed, hydro clutch, dual final drive
Code Vehicle 1st 2nd 3rd 4th 5th 6th Final 1 Final 2
tbc Mk4 Golf V6 (?) 3.417 2.105 1.429 1.088 1.097 0.912 4.200 3.316 *
DRW tbc 3.818 2.105 1.345 0.972 0.970 0.806 3.238(?) 2.615(?) *
ERR Seat Leon Cupra R 3.417 2.105 1.481 1.152 1.167 0.970 3.88 3.10 *
* The 02M gearbox actually has two final drive ratios. The first one is for gears 1st to 4th, the second for 5th and 6th.
02S
6 Speed, hydro clutch, single final drive
FYG Mk5 Golf, Touran, A3 3.78 2.06 1.45 1.11 0.88 0.73 3.65
GLB Mk5 Golf, Touran, A3 3.78 2.27 1.52 1.18 0.96 0.82 3.65
GQB Mk5 Golf, Touran, A3 3.78 2.27 1.52 1.18 0.96 0.82 3.65
GQL Mk5 Golf, Touran, A3 3.78 2.27 1.52 1.11 0.90 0.77 3.94
GQM Mk5 Golf, Touran, A3 3.78 2.27 1.52 1.11 0.86 0.73 3.39
GQN Touran 1.9TDi 3.78 2.06 1.45 1.11 0.86 0.73 3.65
GQP A3 2.0 FSi 3.78 2.27 1.52 1.18 0.96 0.82 3.65
GXV Mk5 Golf, Touran, A3 3.78 2.27 1.65 1.27 1.03 0.86 3.94
More to come on this, with more details of what ratios are in which gearbox variant...
02A & 02J gearbox differences
# The differentials are different. The 02A has push in output shafts on spring clips, whereas the 02J has bolt in output shafts but they are interchangeable as long as you have the correct flanges.
# The crown wheels are the same, but the planet gear/LSD bit that differs, which means that the Quaife LSDs that fit these boxes are different
# There is no difference in the holes that bolt the gearbox to the engine or the starter into the box, - the only difference is in the lower part of the bellhousing where some cars have a (pointless) girdle on that bolts to the underside of the sump.
# The 02J has bigger support webs around the differential area
# There is a slight differences in the fixing points for the gearchange cable support bracket
# The two mounting holes at the wheel end are slightly different as well. They are threaded on an 02J gearbox, whereas they are just holes with an 02A
# The bell housing face that mounts to the block is slightly different
# The selector shaft is different, there are two options; either swap to an older selector shaft, or use the 02J selector shaft with a Mk4 Golf shifter box.
# The 02J boxes out of a 1.8T, the axle flanges are 108mm as opposed to 100mm, so it'll require either custom axles, or swap the axle flanges.
# The 02J 100mm axle flanges part number ends in D, all other 02J axle flange part numbers are 108mm.
02S the 02A replacement?
The research suggests that the 02S found in the Mk5 Golf, A3 and Touran appear to be an 02A/J with an extra cog. It seems that VW have produced a 6 speed without the dual output shafts.
