Does anyone have a solution to this as I don't really want to drive the car around if I'm causing more damage?
This seems to be more common than I thought. It's definitely a whine in 4th mainly on light throttle and if you put your foot down it goes. I might get onto seat and see if they will tell me what it is
Exactly the same situation as with mine. It can't be the box surely as my gears are as tight as anything and smooth but it only does it in 4th?
No doubt Seat will try and talk some dribble and it say you need a new box unless there actually an honest and trustworthy dealers which is hard to find these days
FYI guys
had the Cupra in at seat today, gearbox is out and the release bearing is definitely the faulty culprit.
I also need a new clutch so my bill is £550 but for just the bearing you'll be looking 2-£300
put it in sons 57 plate fr,waste of money and does nothinghttp://www.demon-tweeks.co.uk/Produ...=Google&utm_medium=Base&utm_campaign=Gear Oil
That stuff seems to be mentioned quite a bit when searching gearbox threads.
Sent from my XT910 using Tapatalk 2
well thats funny cause gearbox oil never needs changing and at £55 a go its expensive in my eyesIt does nothing to fix the whine this thread is about, but it is a good oil for your gearbox when the time comes to replace it
