h17och
the hunt is over. 460bhp
Sep 1, 2005
3,504
Dunstabubble
not too sure where to put thread this but....
had a lil leak on my gearbox, booked it in (as its just been rebuilt) for them to take a look.
they said there is no leak, but i know there is, he said to keep an eye on it and see if i see it again.
thats no problem
BUT!!! i started to drive home and about 1mile down the road i lost 1st gear!
i limped home doing 2nd gear pull offs
ive played with cable/adjusted them and now i cant get reverse!!!
when i get a min im going to look at cables undercar.
anyone has an idea what it maybe?
HoocH
other than cables..
there's a lever on the box which engages a lock position-thinks its 3rd gear gate.
shift lever would be in neutral position.
cable spring ends can break or slip
1st place to look.
does box select @ box end?
cable ends are fine.
if you mean the set up thing on the gearlever i dont have it as im on B&M
if you mean gear box end im not sure what you mean!
:confused:
i want to look underneath to check cables havnt melted or anything silly
gonna ring gearbox man 2mz
strange the way it does it after he touches it :rolleyes:
also (maybe realated) after ive given it some beans and im de-accelerating (not always, just time to time) i get a loud hum for about 3 seconds, you can feel it through the wheel
im thinking maybe a combo of flywheel clutch and engine mounts causing it!?!?!
or am i wrong
HoocH
lever is @ g'box end. its used to setup.
cables and ends 1st thing to check
buzzing something touching on overrun?
ill have a play 2n
dont think its anything touching bill as its real loud and the vibrating is strong
what kinda thing was you thinking that may of been touching?
HoocH
had a play with linkage and seems ok at mo! got all my gears back!
how would it of gone out of sync? can the cables slip?
i had to get trading standards involved in the gearbox leak today!! as soon as i told the gearbox man he told me it will be done by tomorrow nite lol
