not technically Seat related, but I know you guys will be able to advise me!
Looking at getting some new wheels for my Racing Puma, which are currently 28mm offset, the wheels I am looking at only come in standard 35mm offset (which sit way too far into the arch) or 15mm. There should be clearance in the mahoosive arches, and the fronts have 10mm spacers as standard which I can take off to make the front wheels 25mm? BUT will there be a problem with vibration or tramlining from running the wider offset? or is it the equivalent of whacking on a set of spacers?
Any help on this? don't want to fork out and then find I can't use them...
