Tall-Paul
Previously ph2858 :D
Nov 12, 2006
671
Manchester and Preston
Hi, I'm after getting something like this offf ebay:
http://cgi.ebay.co.uk/ws/eBayISAPI....=270244932890&ssPageName=STRK:MEWA:PIC&ih=017
but I can only have a 300mm disk due to having 16's so does anyone know how to get a different bracket made so that the caliper will sit nicely on smaller disks? If I was really clever I could draw them up myself.....but I'm not so does anyone know somewhere in the northwest than can?
Thanks in advance! :D
I'm not sure even with custom brackets they'll fit behind the standard 16" wheels as a lot of it is down to the shape of the spokes as well...
Defo 17" minimum to get them under and even then 15mm spacers needed
disc diameter, outer rim diameter, hole pitch, gap needed, difference between 300mm and standard brakes etc. I can source plenty of diagrams. just need to know what you need.
Paul, they mean the brembo bits wont fit behind the wheels. Just go for 312mm's more than enough for 222bhp!
Why not go for drilled/grooved discs with Green/Redstuff pads on the standard setup?
Then no need to worry about clearance - just change to some better discs front and back and some Greenstuff pads. You'll be ok. You're just a girl - you can run 222bhp with standard brakes! :D ;) :lol:
Well im running around on 312mm and they need to be bigger......soon.
