if you strip everything you can off the engine, 2 of you should be able to remove box and engine together - also, if you drop the sump off, you will be able to remove the big ends and take the pistons and rods out, again lightening the job. Then just stick the sump back on once its out of the car
disconnect driveshafts, clutch cable, exhaust manifold,
disconnect single bolts that fasten engine/gearbox to car (3 of them, front, rear, gearbox rear)
2 strong lads, lift the lot out.
SNWAPS affiliation
Ave it
Rob
