Getting Fault Code 19558 and 19557
Aug 27, 2011
649
Quick Google/Ross-Tech brings up the following:
19558/P3102/012546 - Motor for Intake Manifold Flap (V157): No Signal
Possible Symptoms
Hard Shudder when turning OFF the Engine
Possible Causes
Fuse(s) faulty
Wiring and/or Connector(s) from/to Intake Manifold Flap Motor (V157) faulty
Possible Solutions
Check Fuse(s)
Check Wiring and/or Connector(s) from/to Intake Manifold Flap Motor (V157)
Check/Replace Intake Manifold Flap Motor (V157)
Perform Output Test
Seems to be quite a common issue but it happened straight after I put an EGR delete on. Would this be directly related?
Many thanks!
Apr 12, 2010
635
Possible Symptoms
Possible Causes
Fuse(s) faulty
Possible Solutions
Check Fuse(s)
Perform Output Test
Many thanks!
My money says you've a BLT engine code and you've fitted the wrong type of egr delete.
see here http://www.seatcupra.net/forums/showthread.php?t=340731&highlight=egr+delete
for the correct way of doing it
Aug 27, 2011
649
That makes sense to be honest then!
I'm running custom silicone pipes etc. so the ASV doesn't really have space for a jubliee clip to go round it. Would there be any alternative options etc..?
Thanks for the post though. Really cleared it up! Haha.
