I need help!
With my car being due to have an MOT this weekend i thought i should try and get rid of the engine management light (EGR is deleted and its a BLT engine, apparently it cant be mapped out) so my plan was to plug the EGR/ASV bit back in and cable tie it up somewhere so the light could be removed for the MOT. After figuring out it wouldn't fit anywhere under the engine bay i thought i could just remove the electronic bit from under the cap of the valve and tape it up somewhere for a more perment fix. I stripped it down and plugged it back in, then things started going wrong, the power steering light came on, airbag light, traction control, the coil light constantly flashing and the engine management light is still on. Now when i turn the ignition on, the power steering pump is humming all the time. When i start the car there's no power steering and no turbo, like its in limp mode. And sometimes it only runs for about a mintue. Has anyone ever experienced anything like this before? Ive plugged my laptop in with VCDS lite and got these faults, two of which have always been there because the EGR valve is removed.
4 Faults Found:
19557 - Motor for Intake Manifold Flap (V157): Open or Short to Ground
P3101 - 35-10 - - - Intermittent
17957 - Shareware Version. To Decode all DTCs
P1549 - 35-10 - Please Register/Activate - Intermittent
17849 - Shareware Version. To Decode all DTCs
P1441 - 35-10 - Please Register/Activate - Intermittent
16706 - Engine Speed Sensor (G28): No Signal
P0322 - 35-10 - - - Intermittent
VCDS-Lite Version: Release 1.2
Monday, 17 February 2014, 20:41:43.
Control Module Part Number: 6Q0 423 156 AB
Component and/or Version: LenkhilfeTRW V270
Software Coding: 10141
Work Shop Code: WSC 06402
VCID: 6F9150BF3E85
2 Faults Found:
00566 - Steering Assistance Operation
27-00 - Implausible Signal
01314 - Shareware Version. To Decode all DTCs
79-00 - Please Register/Activate
Any help would be much appreciated!!
4 Faults Found:
VCID: 6F9150BF3E85
2 Faults Found:
