that GPS blocker , is it anygood for jamming speed cameras
Only within 6m or so :D
also heard that someone in the VAG dealerships gets their hands on keys for a price
Sadly it will always be the case for any dealers but i guess they are too willing to do the time for the crime nowadays
so can i contact seat for my SKC mine is a 2004 leon tdi would this be immo 2
you can contact them but they will need to have the vehicle present
The 6m thing is it block gps devices within 6m so outside GPS devices are ok. The tracking authority effectively won't see the GPS device.
Have you seen gone in 60 seconds???;)
Well, I managed to pull my SKC code from the ECU using a cheap Chinese clone of VAG K+CAN Commander. I was hoping to post a howto on the forum with screenshots etc. but I can't add images until I've posted 15 times :(
A guide to finding your SKC using VAG K+CAN Commander 1.4
Was it relatively easy?
It's not too hard if you have a reasonable understanding of the concepts involved. I've written a little guide that demonstrates what you need to do to get your SKC.
I can't give you a direct link because I haven't made enough posts, so you'll have to manually copy and paste the following into your address bar:
Code:
ajames.pulsewidth.org.uk/leon/extract_secret_key_code.html
Hope it helps!
BTW, there is a key programming facility in VAG K+CAN Commander, but it didn't seem to work correctly for me. I used VWTOOL (which also came with the cable) to adapt my keys. I can write a guide for that if there is sufficient interest...
I would be very interested in the guide! Think I shall be getting a lead of ebay and give this a try.
Dam my computer tinkering ways!!!!
Just ordered my cable.
Got a 2003 TDI 110. Will let you know how I get on :).
Got my cable and software finally! Yet, I got problems trying to install the bloody program on my laptop. Did you do yours on XP or is it on Vista?
XP for me. The software installed ok but you have to get the USB drivers, can't remember if they're on the CD or not. If not just do a google search.
Cheers, Ill probably quickly wipe my laptop and get XP on it. I couldnt find anything on the disc that would resemble the drivers. Ill pop it in on google. Hopefully I might get my transponder coded then finally my key is all sorted :D.
Grrr, still having difficulty getting the program installed. Im running at full admin and still wont give me access rights :/.
Not sure what Im doing wrong :confused:
Ive got the VAG commander one, hoping to use deltrons guide to getting the code.
Got the drivers installed, but doesnt want to run the VAG Commander setup, does it have to be connected to the car in order for it to install.
