got my brakes on today
owen lcr
orvil
Oct 10, 2006
1,179
montrose, scotland
i am offshore at the moment so cant get part numbers, i did give agent me part numbers for discs so you can get them form him in the meantime. i am going to get the calliper numbers when i get home in a week or so
owen lcr
orvil
Oct 10, 2006
1,179
montrose, scotland
well i have only done about 200miles on them and only used them in anger twice, and they are wow... the only thing is that they are to powerful for the rears now so in the process of having s3 rears fitted at the moment so that should even it out slightly
cheers guys
Chris_Cupra
108
Athens, Greece
Very nice and useful upgrade ...!
Would you mind to ask you the following ?
1. What is the size of the disks ? 360-365mm ???
2. Is your LC on 19" or 18" wheels, as I am unable to judge from photo...?
3. You said that this combo requires 5mm spacers...! Did they use the original bells coming with the RS6 disks or they required new custom ones ?
Thanks in advance !
owen lcr
orvil
Oct 10, 2006
1,179
montrose, scotland
1. they are 365 from memory
2. they are 18" wheels but do not fut under OEM wheels thus why i have team dynamics with 5mm spacers
3. Everything is a direct fit onto the oem hubs apart from a small shim between oem hub and RS6 disc.
very good upgrade in my opinion
mYGeL
Cupra Widebody
Hi
Woow looks awesome! :D
I have the same Calipers here, just looking around what discs would fit.
Then i found your thread! :D
So the RS6 discs is a direct fit?
How much shims is needed? in mm?
Brackets are they sold anywhere that will fit?
Or does somebody have a drawing so i can get them fabricated?
what pads are you using?
Will the EBC Yellow stuff work fine?
best regards// Michel D. Sweden
Poverty
Ohhh they are mk1 rs6's I thought Owen had mk2 ones fitted, as mk2 rs6 brakes won't fit under 19's
Poverty
The above statement is incorrect. They will fit under 19s! And I believe this is the mk2 rs6 setup!
