Update
Yesterday afternoon i started getting the engine ready to be put back in, my mate popped round with my engine lift so there was no stopping me
I pushed the car back out of the garage a bit to give me some space at the front.
Had a tidy up then assembled the engine lift. Used ratchet straps to lift it (i know they shouldn't be used for lifting but i locked them by closing them fully)
Took the weight of the engine in the stand -
Unbolted the stand from the engine to access the flywheel end of the engine. Whilst i had it free i tapped all the holes out to get rid of excess paint.
Next up i got the new ARP flywheel fixing bolts out of the spare room along with the Eka diamond coated friction disc.... this is to improve friction between the flywheel and crankshaft -
I then checked the length of the bolts, thickness of the flywheel and then the thickness of the flange on the crankshaft.... this was just to make sure the bolts didn't bottom out against the main bearing cap. All was good.
When i installed the the ARP front crank pulley bolt i found the torque required was massively different between loctite, oil and ARP Lube.... it was noticeably different when tightening them both, the bolt felt notchy and banged as it was tightened not good for me.
So for the ARP Flywheel bolts i put ARP lube on the threads and under the head this allows the bolt to stretch nicely without the added friction from the head and threads.
All fitted -
I then lowered the engine down onto a crawler to protect it. This was so i could torque the flywheel bolts up properly.
For the last stage i had to put a breaker bar on the crankshaft bolt at the from to stop it from turning.
I torqued the bolts up in stages - 20lb/ft then 40, 60 and finally ending on 80lb/ft - the sheet that came with the bolts from IE said 64lb/ft but at that torqued level the bolts didn't feel like they were stretching at all so i added a bit more at a time until they felt good.
I then checked they were no clearance issues with the sump or girdle plate (there sometimes is with aftermarket flywheels) loads of clearance -
Next up was mounting the clutch assembly on the flywheel. To do this you need to centralise the clutch plate. When i bought the Clutchmasters FX400 it came with an alignment tool which didn't fit my crankshaft (probably as its a 1.9tdi crank) so a few months ago i bought a generic clutch aligning tool from machine mart... gave it a go and this also didn't fit![Furious    [:@] [:@]](/forums/styles/seatcupra/oldforumsmileys/furious.gif)
So i started trying sockets in the holes and found a perfect fit - a small 3/8 spark plug socket that the drive end fitted perfect in the crank and the other end fitted perfect in the clutch plate
After that i put the pressure plate on and installed the outer bolts with loctite, carefully torquing them up around the circumference of the clutch so nothing warped or bent.
All done - just offering up the gearbox -
I struggled on trying to fit it for a while, phoned a friend and he was busy so just started packing the gearbox up to get the angle and height correct.... in the end it went on but as it did the clutch slave cylinder (which i'd previously primed with brake fluid) obviously got compressed and it "came" brake fluid all over me in the excitement i felt dirty, but kinda enjoyed it lol.
Next up i moved everything around and re-strapped the engine to take the extra weight of the gearbox on the end. I took the fuel rail & injectors off as the straps may have damaged them. Then fitted the BFI engine & gearbox mounts.
Started lifting it in -
As before when i originally fitted the engine i had to draft the big guns in so i got the wife to give me a hand. It put up a good fight but we got there in the end -
Todays job is to final torque all the engine mounting bolts up and to fit the Dog-bone mount.... then who knows wiring loom / starter etc.
Thanks For reading and any comments,
Cheers,
Graham.
All fitted -
Cheers,
Graham.
