Wow guys......
But to throw a spanner in the works , I dont think that VAG make their own sensors
So I wonder who does :rubchin:
Then if the manufacturer sells them....I am sure the quality will be the same?
Sarah
Wow guys......
Sarah
Adam not sure if you are aware the upgraded item from seat is the green one, that replaces the original oem faulty one.
Then why don't you tell us and we can source it as a patent part![]()
You should be aware that the sensor package, wherever you get it from and whatever its colour, has two completely separate sensors contained in it. One feeds the ECU, from where the Climatronic unit gets its signal, and the other goes directly to the dash gauge.
My guess is that the dash gauge needs a different type of sensor, as it is an analog meter.
Yes, but I think you missed my point:
One component, the coolant temperature sensor.
Two completely separate sensor elements within that component.
One electrical connector with four blades, two per sensor.
So the dash gauge can fail without any effect on the ECU signal.
ThanksI'm not sure the dash gauge is electronic, it may be simply electrical, a voltmeter measuring the voltage drop across the sensor with no ananlog-to-digital conversion. Sensors are always analog, and the dash dial is analog as well.
