Yup. OEM code is 059 919 501A or AKT. But people ask at the store or search eBay, find out a genuine VAG sensor or another from a good supplier is about $30, and they seek the equivalent code from a cheaper, $5-10, producer. Which may sound great at first, then, after 6 months, it cracks.
According to VAG-COM, it's over or under reading but can'r remember which. I am not sure how this would affect the car though?
Potentially in a whole list of ways:
Copyright AA1Car http://www.aa1car.com/library/coolant_sensors.htm
Engine Coolant Sensors
The engine coolant temperature (ECT) sensor is a relatively simple sensor that monitors the internal temperature of the engine. Coolant inside the engine block and cylinder head(s) absorbs heat from the cylinders when the engine is running. The coolant sensor detects the change in temperature and signals the Powertrain Control Module (PCM) so it can tell if the engine is cold, warming up, at normal operating temperature or overheating.
The coolant sensor is extremely important because the sensor's input to the PCM affects the operating strategy of the entire engine management system. That's why the coolant sensor is often called the "master" sensor.
Many of the fuel, ignition, emissions and drivetrain functions handled by the PCM are affected by the engine's operating temperature. A different operating strategy is used when the engine is cold than when it is warm. This is done to improve cold driveability, idle quality and emissions. Consequently, if the coolant sensor fails or is giving the PCM a false reading, it can upset a lot of things.
HOW THE COOLANT SENSOR AFFECTS ENGINE OPERATION
Input from the coolant sensor may be used by the PCM for any or all of the following control functions:
* Start up fuel enrichment on fuel injected engines. When the PCM receives a cold signal from the coolant sensor, it increases injector pulse width (on time) to create a richer fuel mixture. This improves idle quality and prevents hesitation while the cold engine is warming up. As the engine approaches normal operating temperature, the PCM leans out the fuel mixture to reduce emissions and fuel consumption. A faulty coolant sensor that always reads cold may cause the fuel control system to run rich, pollute and waste fuel. A coolant sensor that always reads hot may cause cold driveability problems such as stalling, hesitation and rough idle.
* Spark advance and retard. Spark advance is often limited for emission purposes until the engine reaches normal operating temperature. This also affects engine performance and fuel economy.
* Exhaust gas recirculation (EGR) during warm-up. The PCM will not allow the EGR valve to open until the engine has warmed up to improve driveability. If EGR is allowed while the engine is still cold, it may cause a rough idle, stalling and/or hesitation.
* Evaporative emissions control canister purge. Fuel vapors stored in the charcoal canister are not purged until the engine is warm to prevent driveability problems.
* Open/closed loop feedback control of the air/fuel mixture. The PCM may ignore the oxygen sensor rich/lean feedback signal until the coolant reaches a certain temperature. While the engine is cold, the PCM will remain in "open loop" and keep the fuel mixture rich to improve idle quality and cold driveability. If the PCM fails to go into "closed loop" once the engine is warm, the fuel mixture will be too rich causing the engine to pollute and waste gas. This condition may also lead to spark plug fouling.
* Idle speed during warm-up. The PCM will usually increase idle speed when a cold engine is first started to prevent stalling and improve idle quality.
* Transmission torque converter clutch lockup during warm-up. The PCM may not lockup up the torque converter until the engine has warmed up to improve cold driveability.
* Operation of the electric cooling fan. The PCM will cycle the cooling fan on and off to regulate engine cooling using input from the coolant sensor. This job is extremely important to prevent engine overheating. Note: On some vehicles, a separate coolant sensor or fan switch may be used for the cooling fan circuit only.
