Is it just clipped on or screwed on, once I've got the bumper off?Bumper off mate awful job to get to, but pretty simple
Pretty sure it’s just clipped inIs it just clipped on or screwed on, once I've got the bumper off?
Sent from my SM-G950F using Tapatalk
So will I not be able to unclip it with the bumper still on?Pretty sure it’s just clipped in
NoSo will I not be able to unclip it with the bumper still on?
If you do decide to take it off I'd invest in 4 more of them 4 pop out screw things on top of the grill as they are sometimes a pain to get off and the head snaps off if you try and force it.
I've took it off before to fit the front splitter and I used your guide then which is really good, i was just hoping i didn't have to take it off just for the trim lol.
Yeah that's how they should work, but mine once you turned them then tried to lift the head up wouldn't budge at all so had to use a flat head to pry them up and some of the heads snapped.They pop right out if you turn the inner screw part 1/4 turn
I've took it off now and you need a screwdriver to push down some of the clips and you wouldn't be able to get to them with the bumper on, so definitely bumper off job.How do you actually unclip that piece of trim? Is there no way you can read down from the top and up from under the car to undo the clips?
