Deleted member 9043
can get the turbo for cheap,
can i use 225 TT injecotrs for this turbo?
is it still ok to put this turbo on my car with 100.00 KM!
an if i map it save is this a better turbo than k04-023? and what about lag?
grtz
im sure you can still use tt injecters with 4bar fpr.
Does gt28rs elminator kit just bolt stright on to same manifold and downpipe as gt2x?
I don't think you'll get enough fuel (by a long way) using TT injectors.
ok im talking about the real gt28rs not eliminator
so you think the TT injectors+4 bar fpr are to small for this turbo?
Yeah i will be gettin every measurement i can as the pag mani is over cylinder 2 and 3, but as its underslug the overal size from block to outer turbo casing should be smaller than a normal ATP type mani which you found didnt fit.
There is another kit being developed which a semi tubular top mount T3/T40E which uses another downpipe which bolts to your existing downpipe, kinda like an eliminator but a proper turbo and a nice mani which i'm thinkin about goin for.
Iam not liking the sound of mounted over cylinders 2 and 3, there really is not a lot of room for DP, needs to be over 3 and 4 really. But its got to wortha measure up.
