So your tank 'fills up' according to the gauge as you drive and use petrol?
Hooch you have officially made the first petrol producing car! Now you will be syphoning the full tank every few hundred miles and putting it in storage to sell instead of having to fill up! :clap:
its sounding like a mod morksport would be interested in.... fame awaits.
i reckon turning the fuel tank upside down would help :doh:
keep it coming.... awesome car
currently seeing 10-11's :1 afr with 630cc 3bar.
anyone got any ideas to lean it off?
tryed 399cc injectors at 3 and 4 bar, no luck.
ive ordered an adjustable fpr to try 5 bar!?
custom code dont want to know
cheers
HoocH
what kinda maf are you running? and remap?
maybe a bigger maf
what other remappers have you talked to?
3" maf. running my old gt28 map . mapped for 475cc but cant find any :(
spoke to other mappers about mapping my car but not playing with custom code.
or if i find someone with a serial lead i can use custom settings to lead it off..
Hooch
Have you tried Awesome.......Jeff who worked on my car used to map and work for Ian Birch @ Dubsport....he's pretty spot on for custom mapping....well worth a try
Ian
Im not sure if WRC at silverstone are still going? I did hear they where closing down? But Chris from there is apprently a very good mapper.
Jus thought id mention it as your not far away from him at all if there still at silverstone.
thanks for info guys but im sorted for my final map its just i need a temperary fix to lean it off to run it in!?
mork, larger maf...? like r32 rs4 etc?
my vag com is currently playing up :( i can get one tho
i will download tonight.
what will i need to do once ive downloaded? anyone a pro with it?
a quick discription of what i gota do would be good, or is it self explanitry
thanks for the link
HoocH
yes
Your cable a usb one? I use it with my hex-com canbus vag-com lead, and use custom settings when using my cc flashing cable.
unitsettings is handier as its used in combination with vag-com logging to trim channels etc.
Thanks for sorting the link bill.
It looks pretty self explanitary to use to be honest. Its just removing or adding a percentage of the options it gives you.
Rod/Piston
hi
i would like to ask u from where u bought the pistons and the conrod coz i have to buy for my leon 1.8 turbo can u provide me from where i can buy them
ths alot
no real updates no.
just stuck an adjustable FPR in and booked in for mapping on the 21st june :)
also been told not to drive it due to the richness :(
