must be running a soleniod of some sort off the external wastegate?
looks like the gain is set to high to me to aid spool this intern will cause a spike.
missing some of that graph!
as my boyfriend said. 1.9bar boost.
rs fab wont warrent it with out a brace as ive already said what youi told me and this was before they even started building it.
the plumbing is as alex said. TB connection tee's one way to a bleed valve and other way to top side of WG. which to me seems weird because rather than restricting boost to the wastegate its just bleeding it off which i doubt it can do fast enough.
i think the problem is its over boosting which is causing the wastegate to chatter. i may try to borrow a inline bleed vale if some one wouldnt mindand have a play.
also wouldnt mind borrowing a forge 006 if anyone feels nice![]()
also what does a battery light mean on dash?
im guessing incorrect output from alternator?
comes on as i come on boost?
does knackered alternator do that?
