Guest, New Stock alert: Premium CUPRA valve caps now available in the store ? Order now from the merchandise store
Your Fp Green had a td06h turbine wheel hence no surge as it is sized correctly to match the comp wheel same with the red.A 20g comp wheel with a td05h turbine is a mismatch as our good friend john banks said years ago.
steve has a td06h 8cm
nope changed the hotside from 7cm to 8cm which gave me another 27bhp but i still get surge between 4700-5000rpm.yours is a td05h/20g isn't it steve? hence the surging.
on a 7cm it started spooling at 3200 and with the 8cm it spools at 3500rpm and that's with a largeport,nice intake mani and large throttlebody.that not laggy on 8cm?
killed a good 500-750rpm of spool when i ran the 8cm on the green cartridge.
all i know is that they fitted a larger 8cm hotside which i was told would make it a td06/20g.obviously not thenI'M NOT TALKING ABOUT THE EXHAUST HOUSING A/R,I'M TALKING ABOUT SIZE OF THE EXHAUST TURBINE WHEEL, IE: TD06H Turbine Wheel : Inducer Dia.: 67.3 mm Exducer
Dia.: 58.8 mm
TD05H Turbine wheel. Inducer Dia 55.9mm Exducer 49mm
Which do you have ?
that'll be where mines going wrong then.turbo not right spec for my set updifferent spec comp wheels tho. no surge ever
that'll be where mines going wrong then.turbo not right spec for my set up![]()
right ok i understand now,this would explain it maxing out at 400bhp as it's not a full td06/20g.i did wonder how mark gunns corrado was doing 460bhp when he had a td06/20g fittedWhat your saying i think is that you bought a TD05H-20G 7cm turbo then fitted a 8cm housing which would help but not alot.What you need is the TD06H turbine wheel to see the full potential of the 20g wheel.
