ok sounds good.
Is it best to flush out the system first with water till it runs clear at the bottom and then do up the tap, fill it up again and put the lid on the header tank. Then idle or drive with the heater on full and then drain again and fill with coolant.
I take it this should get rid of any air etc?
Did this using the guide and it took about an hour and a half. The longest time was finding the tools I had that would get to that bottom bolt.
In the end I got a 10mm spanner from my neighbour that was only about 4-5cm in length and still had the fully round end aiding in small movements. Worked a treat![]()
All the pics have gone shame as it was a good resource, found this http://webcache.googleusercontent.c...ewtopic.php?t=56316+&cd=1&hl=en&ct=clnk&gl=uk
