They are better thanks but not brilliant. According to the technician the offside cable was stuck. Both cables are now lined up under the ashtray. I was told that this fix wasn't covered by the warranty but that they'd done it free of charge anyway.
I'm not convinced that its as good as new though. The footbrake still travels quite a bit more than I feel it should, so it either needs a good bleed or there's something else wrong. I can still get the ABS to kick in but the distance the pedal has to travel seems excessive.
The pedal doesn't quite go to the floor before stopping - I can just get my other foot underneath it. If I stamp on the brake it is solid, but if I press it slowly it sinks. Is this a sign of air in the system? The pedal hisses quite a bit as its going down.
With the pedal pressed, the handbrake has at least another 2 clicks more than when the pedal is not pressed.
And with the engine off, if I pump the brakes til they are hard, there is still a tiny bit of "spongy" movement before the pedal stops moving (if that makes sense).
I was expecting the car to come back perfect, but I guess to take it to the
garage a second time I will get charged.
Cheers for the interest.
