ja2007
70
hi guys
need info,my rad is leaking.has anyone every changed a rad on a lcr if so can anyone give me any tips (other than going to the dealer)
thanx
A small piece of advice really, would be to go to a specialist.
However if you are mechanically minded, its quite easy, but a bit of a ballache.
Take off the bumper, and the upper grilles.
From here the easiest thing for you to do, would be to take off the front panel (Dont forget the 2 bolts at the wings).
Then take off the 8 supporting bolts either side of the front panel.
Disconnect all hoses etc etc from the rad.
Fitting is the reverse of removal.
Any problems shoot me a PM.
cant you change raditor with out removing the bumper?
i changed mines on my pulsar! just tooks of the 2fans then bolts for the raidtor and it came niceley!
